Go Back   Motorcycle Forum > Motorcycle Forums > Vintage Forum
Vintage Forum Talk about your vintage motorcycle in this forum.
Old 04-16-2007, 01:09 PM   #1
65Bonneville1
Newbie
65Bonneville1 is on a distinguished road
Question 65 Triumph front end question?
I'm rebuilding a 65 Triumph Bonneville 650 bobber that used to be beautiful, til it sat outside for years ! I'm finally doing it, and the engines apart. My question is - is there a bearing conversion kit or anything available where I can use a springer front end that's most likely set up for a harley on it? Or will I have to have the frame cut and have a harley neckpiece welded on to do that (something I can have done, but would rather not do).
65Bonneville1 is offline   Reply With Quote
Old 04-19-2007, 09:52 PM   #2
Maico Shark
Maico Shark's Avatar
Maico Shark is on a distinguished road
Well when I was involved in building customs everyone made stuff for the Triumph as it was chopped as often as Harleys. For sure there's about every type springer around made specifically for trumpets, whether they still are making them is another question. I'm surprised no chopper supply place has hit on our forum. It's a great bike to build, has good sound, good speed, and a lot of heart. Post a photo of what you got and when you finish.
Maico Shark is offline   Reply With Quote
Old 04-19-2007, 11:23 PM   #3
65Bonneville1
Newbie
Will do, thanks a lot !
Old 04-24-2007, 02:05 PM   #4
TRUKERX
TRUKERX is on a distinguished road
Cool TRIUMPH FRONT END BEARING CONVERSION
TRIUMPHWIZARD ON E BAY MAKES A BEARING AND RACE CONVERSION FOR TRUMPS. ABOUT 40 BUCKS GETS YOU WHAT YOU NEED TO ADAPT ANY SIZE STEM TO YOUR NECK WITHOUT CUTTING OR WELDING. I AM BUILDING A 67 TRUMP 650 BOBBER WITH 71 EXTENDED FRONT END,LET ME KNOW HOW YOUR DO'IN.
TRUKERX is offline   Reply With Quote
Old 06-06-2009, 11:14 PM   #5
yenkocorvette
yenkocorvette is on a distinguished road
Have a british title & British plate from a 70 Boneville if interested
yenkocorvette is offline   Reply With Quote
Old 06-11-2009, 12:35 AM   #6
HondaIlya
HondaIlya is on a distinguished road
i love it how everyone is trying to sell something nowdays lol
HondaIlya is offline   Reply With Quote
Old 06-23-2009, 08:42 PM   #7
BritBiker
BritBiker is on a distinguished road
most harley neck stems are one inch and the Triumph's are smaller.
The Triumph timkin bearing conversion kit has a one inch inner diameter, but you'll have to press out the top dust cover that is inserted to compensate for the smaller Triumph stem size... that should do the trick...
BritBiker is offline   Reply With Quote
Old 08-23-2009, 10:25 PM   #8
k6-750-va757
k6-750-va757 is on a distinguished road
i did the same thing on my 71 tri i have a springer front end i had the 1inch bolt machined laythed down to fit the stock bearing .. works like a carm only cost $20 buck at a local chopper shop !!! i will start a build thread soon.
k6-750-va757 is offline   Reply With Quote
Search this Thread:
Advanced Search
