Old 11-12-2006, 03:16 PM   #1
Sparg93
Newbie
Sparg93 is on a distinguished road
Default '99 CBR F4 stalls when hot
When my bike warms up from frequent stops it easily stalls.
The bike operates within a normal temperature range, but does stall towards the warmer end when frequent stopping occurs.
On a side note, the bike starts up very easily when ice cold with very little choke applied.
Sparg93 is offline   Reply With Quote
Old 11-13-2006, 09:52 PM   #2
CB750F
Shantytown Mayor
CB750F's Avatar
CB750F is on a distinguished road
Sounds like its running overly rich (like getting too much fuel) when warm. The first thing I would do is pull the air filter and see how cruddy it is. If it checks out ok or is fairly new then my next order of business is give it some new plugs. When you pull them out if they are all black on the tips you are deffinatly getting too much fuel. Then its time for either carb adjustments or a good carb cleaning.
Don't rule out an ignition problem. When things get hot, parts like the coils and CDI sometimes fail but will work when cool.
CB750F is offline   Reply With Quote
Old 11-13-2006, 10:04 PM   #3
Sparg93
Newbie
hmm, air filter is a new K&N and the plugs are also new.
I'm new to bikes, but where could i find "coils" for the bike? What is a CDI?
Old 11-14-2006, 10:11 PM   #4
CB750F
Shantytown Mayor
CB750F's Avatar
You can get ignition coils at any Honda shop but they ain't cheap so you'll want to have yours tested.
A CDI is a type of ignition. It means Capacitive Discharge Ignition. Some folks refer to the CDI module as the "brain box". Those too are also expensive and may not be the problem. If you aren't real familier with working on motorcycles you may want to take it someplace to have it worked on. Your problem although seems simple could be fairly complicated and does require a good bit of specialized equipment to figure out exactly what is wrong. You can just keep throwing parts at it until ya hit the right one but that really gets pricey.
I'm leaning towards something with the carbs though it is tough to tell without the bike sitting in front of me.
Search this Thread:
Advanced Search
