#1 |
Super Moderator
Okay, going after the carbs and just spent $200 on clutch assembly.....she is aslippin'.....650 Vstar
17K for Stator and pickup coil; carb sync; tires 30K for clutch; carb sync 3K for oil change; air filter if needed Daily tire pressure
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. The woman who follows the crowd will usually go no further than the crowd. The woman who walks alone is liable to go to places no one has ever been before. - Albert Einstein |
#2 |
Super Moderator
Got her all done....
Brian helped me with the exhaust, so I didn't have to pull it all apart, and the brake pedal...then I did the rest....replaced the clutch plates. Just be sure to look at the notches at the top of the ones you are removing, keep them all in order and look at how the plates are placed in....for my bike the rounded side went in towards the bike. You also have to soak the fiber ones for an hour in the oil you drain from your bike.
#3 |
Cruising the retirement highway
So if I get this bike I am going to look at on Saturday, You are the person to come to for help, correct?
