Go Back   Motorcycle Forum > Motorcycle Forums > New Member Introductions
New Member Introductions Come on in brothers and sisters. Stand by the fire and tell us about yourself, about your ride, or whatever...
Old 05-19-2012, 01:30 PM   #1
rtdoyle
Newbie
rtdoyle is on a distinguished road
Default 2004 650 vstar fuel problem
I am a new rider, my wife and i purchased motorcycles,2004 650 vstar for her . The problem , no fuel getting to the carburator.Did all the tests and checked the fuel pump,it is good.Unplugged the electrical connection at the fuel pump and when i turn the key on i get 12 volts coming from the fuel pump relay,but as soon as i plug the connector back into the fuel pump and turn the key back on i only get 0.3 volts. anyone with suggestions would be greatly appreciated. Fuel pump and fuel pump relay have been tested at dealer and are good.
rtdoyle is offline   Reply With Quote
Old 05-19-2012, 03:31 PM   #2
mitchberry
Powder Coating Service Austin Texas
mitchberry's Avatar
mitchberry is on a distinguished road
welcome
if it were me, i'd replace the fuel pump and relay. technically, it shouldn't be old enough to be bad, but that's usually a good start.
aside from that, before you go throwing money at it, make sure the gas is actually leaving the tank, and that the lines aren't in a pretzel or tweaked or running up hill.
shouldn't matter as much if it's up hill if you have a fuel pump, but sometimes air in the lines can cause it not to pump... air can get trapped in the line..
also make sure all of the hoses are plugged in correctly.
has this been an issue from the start, or is it something that developed recently?
mitchberry is offline   Reply With Quote
Old 05-19-2012, 06:56 PM   #3
rtdoyle
Newbie
fuel pump and relay have been tested at the dealer and are GOOD.
Old 05-19-2012, 07:04 PM   #4
rtdoyle
Newbie
Realized that I should have posted this thread in motorcycle repair section.Creating a new thread in that section.
Search this Thread:
Advanced Search
