#1 |
Motorcyclist
OK first post on this forum. I got a 2000 v-star 1100 classic, very high idle while driving till I come to a complete stop, then it goes down to normal set idle after a few seconds. Ive seen this problem with my searches but haven't found solution. This will happen even if I jack the rear tire off ground, blip throttle and returns right to set idle, if I rotate the rear tire and blip the throttle it will stay high until I stop the tire. It is NOT the cables/choke sticking. If I unplug the speedo sender unit it goes away and operates correctly. I have purchased used parts and installed both the speedo censer and the cdi box thinking it was one of them having issues, (one of the wires are connected from senser to cdi) to no avail. I do not see how this could be a vacuum leak or exhaust leak, or jets clogged up. Any help or ideas will be appreciated, locale repair shop has no idea how these symptoms are related
#2 |
I sent you a private message....let me know if you get it.
'08 Yamaha Road Star To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Super Moderator
Sounds weird, but check all of your fuses....they are known to loosen up and cause a lot of problems, especially the one's under the seat!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. The woman who follows the crowd will usually go no further than the crowd. The woman who walks alone is liable to go to places no one has ever been before. - Albert Einstein |
#4 |
Administrator
This is a carbed engine, correct?
I can't figure out how the speedometer sending cable has anything to do with the idle.
#5 |
Motorcyclist
Its carburetor's, and it's electronic speedometer (no cable). Pickup censor over the drive shaft. I was thinking the cdi adjusts the advance for mph. The censor speedo pickup is connected to the cdi box. Ive run out of ideas. Replaced both cdi and speed pickup with used parts to no avail.
#6 |
Motorcyclist
Thanks Raven, I will look at that today.
#7 |
Super Moderator
I had a vstar that ideled oddly occaiionally. It was just some leaking seals. I do not see how the speedo and carb are connected. I will join this thread just to see how this works out.
#8 |
Motorcyclist
Thanks Badlands
#9 |
Motorcyclist
#10 |
Is there a throttle position sensor on that bike?
#11 |
Motorcyclist
yes Ive set it with an ohm meter but dont think it was off. It will even do it if I roll backwards and blip the throttle it stays around 1500-2000 rpm. untill I come to a complete stop and then it will return to set idle
#12 |
Having the same problem with my idle any ideas on how to fix this
#13 |
Motorcyclist
I think it was the throttle position sensor on the behind the air filter, it was just out of spec. but like it was turned all the way in one direction. if I remember right when you loosen the screws you can rotate it IDK maybe 1/2 turn, and it was bottomed out in one direction and was right at the high end of the spec. so I had to replace the screws that hold it in the carb and get rid of a washer that was holding it from turning more to be able to get it into a mid spec. I hope this is clear to you. Brad
#14 | |
Banned
I've noticed that my "new to me" Vulcan idles faster in gear than it does in neutral. Because I set my idle speed in Neutral, I now need to tweek it back just a bit. I think only a mechanic who is familiar with that particular model would know for sure. Not the same as what you are seeing but similar maybe. I think your condition borders on dangerous though. |
#15 |
Motorcyclist
My problem is solved now, I didnt consider dangerous but I was ready to sell the bike. No one could resolve the problem and I lived with that for way to long. Hope this thread will help someone else
I tried to post pick of my bike but it wont let me |
