#1 |
Newbie
I've got a 98 suzuki intruder vs1400, the other day, i noticed my indicator lights for neutral, turnsignals, oil pressure, wern't coming on, and in fact, my brights and signals and breaklights wern't working. found that the fuse had blown, i replaced it and everything worked again. but after riding for 20 - 30 min, the fuse will blow again. i've replaced it a couple times and always the same result. any ideas? its a 10A fuse
#2 |
Administrator
You likely have a short in the electrical system causing the fuse to blow. The wiring will need to be traced and checked until you find the source.
