| Building, Restoration & Modification Building a bike, restoring a classic, or making some modifications? |
#1 |
Banned
I have had my bike for a few years now, and last spring, I came very close to buying a Yamaha R1 to build as a track bike. Well, I am a father of twins; which had me thinking about the purchase of a second bike, and how it would double my maintenance expenses.. It would have also left me with a motorcycle that would hardly be ridden. SO I opted to take the money I had set aside for a second bike, and spent it on building up the FZ1.
This is what the bike looked like when I purchased it. It is completely stock, minus the S/O exhaust, and the Corbin seat (not pictured). ![]() In the first couple of years, I added pod filters, rejetted the carburetors, cut the fender, added the frame sliders, bar end mirrors, and made a few other minor changes. ![]() Finally, when I parked it in April 2011, I went with the full monty. I decided to upgrade the suspension, brakes, Ti-Force racing exhaust, and add a custom set of needles, compliments of Glenn Hinton. I installed R1 wheels, which gave me a 6" rear rim, up from 5.5". This allowed for a 190 tire. It slowed the turn in just a tad, yet gave it more of a stable feel with the slightly larger contact patch. Here are the wheels all ready to go onto the bike. I had to have a wheel spacer fabbed up to get the R1 rear wheel to fit, as well as modifying a rear caliper bracket from an R6, because the rotor placement was totally different on the wheels. ![]() ![]() The front wheel provided it's own challenge. The rotors on the R1 are 320mm, and the FZ1 are 298mm. There is also a difference in the lug pattern. My solution was to purchase rotors for the FZ6, which met both criteria. I also went with the front master cylinder from an '07 R1. It added more stopping power, given it's larger piston size. I also added custom HEL SS brake lines to go along with the new MC. This required me to fab up a mounting bracket for the fluid reservoir, which I made from a mirror post. ![]() To improve the suspension, I contacted Lee at Traxxion Dynamics. I decided to send off my forks for the once over! Had the Axxion AK-20's installed, and added the Penske 8983 on the rear. May I say, it was the best modification to date! ![]() Since some of the suspension parts were on back order, I decided to add some HID headlights. I went with the Xenon Bi-HID's. Using two colors, both the 3k, and 6k IIRC. At 35 watts, they use less energy, and they are significantly brighter than the OEM lights! I also took the extra down time to add some Woodcraft racing engine covers, CRG bar end mirrors, alarm, and some Pro-taper motocross bars. I also managed to find some carbon fiber inserts for the fairing, some side covers, and trim for the instrument cluster, and top clamp. Oh yeah... a bellypan, and a PIAA horn too!! I also purchased a pair of brake calipers off of an '09 FZ1. Since the calipers had silver, rather than the blue bolts that are on the OEM calipers. I wanted to get all of the blue off of the bike, since it really didn't fit... ![]() ![]() ![]() I am pretty sure that about covers it... This is what the bike looked like once I was finished with all the work. I also took it to Salt Lake Motorsports, to put it on their dyno. I wanted to dial in the jetting after making all the changes to the bike, as well as getting a good idea of how much power I was putting on the ground. I found out I needed some minor adjustments to the A/F mix, and that I am getting 134hp to the wheel. That is about a 15hp increase over stock. ![]() |
#2 |
Administrator
Looks nice mang, love the CF dash work.
#3 |
Super Moderator
Yes, that thing is bad.
Now where did you say that spare key was again?
#4 |
Banned
The spare is hanging on a nail in the garage, right next to the bike.
