#1 |
I just inherited a CB360 that's spent most of its life sitting, its a 75 and has less than 2K miles on the odometer. At any rate two years ago my brother got it back into working order but not knowing about non-detergent oil filled it up with SAE oil. He rode it for about 300 miles and progressed to a 750 Nighthawk... and along the way learned a lot about maintenance. He did not however change the oil, which I'm about to do. It doesn't seem to slip form what he told me, so I'm wondering if I should just forget about it and ride on, or should I do some preventative maint and change the friction disks? Thanks for any insights.
#2 |
Super Moderator
I'd drain it, put some 15w-40 Shell Rotella in there, and see how it rides.
I'll bet its fine. |
#3 |
The Rainmaker
First off:
You don't want non-detergent oil. If the oil he put in the bike was not labeled "Energy Conserving" in the API circular label on the container, no harm done. If he used an oil labeled energy conserving, I would change both the oil and filter. Not sure the CB360 had a filter so you might only need to change the oil. You do need to use oil that meets certain API standards, but it should not be labeled Energy Conserving. I don't know off hand the API standards for oil to be used in a motorcycle. You will need to research that yourself.
Charles |
#4 |
Thanks guys, an oil change was in her future anyway, along with some braided stainless brake lines. I think it has a centrifugal oil filter, so I'm going to read up and see about cleaning that out too.
#5 | |
The Rainmaker
The reason for not using energy conserving oil in a wet clutch motor is the thought that the increased slickness/lubrication properties required to earn that designation can cause the clutch plates to slip. Sounds logical. (Kinda) I have never experienced that since I have never used the energy conserving oil in a motorcycle.
Charles |
#6 |
Energy conserving oils have molybdendum disulphide (MOLY) in them as an alleged friction reducing agent. The fiber on the clutch plates will soak it up and slip. Once loaded up with moly, the clutch is hosed.
#7 |
Veryfried
you want a 10w40 in a cb200 mate.... 15w is too thick and could cause clutch problem.
you wont have caused any damage by running wrong oil but get it good & warm before changing it out & clean the oil filter too |
#8 |
Whats the interval that the centrifugal filters are supposed to be cleaned out, and does it require any special tools outside of those required to get the side cover off?
#9 | |
The Rainmaker
My early Hondas had a tendency for the screws to be extremely tight. My best results removing them were when I used a hand impact driver. You can buy them for under $10 or as much as $80. The cheap ones have always worked for me.
Charles |
#10 | |
h ttp://i73.photobucket.com/albums/i235/thatoneguy82/CM91%20project/Picture039.jpg h ttp://i73.photobucket.com/albums/i235/thatoneguy82/CM91%20project/Picture041.jpg |
#11 | |
#12 |
Challenged Mechanic
#13 |
#14 | |
Challenged Mechanic
Cheers, Mike
#15 |
LWRider, I might follow that mantra. Unfortunately my fork seals are bad, really bad. The swipes are all kinds of cracked, and there's fork oil all over the tubes. I haven't got a proper manual but I do have the original service manual, it does not however cover how to disassemble the forks, only how to change the oil in them.
