Old 05-19-2011, 01:03 PM   #1
jwbookworm614
Master At Arms
jwbookworm614 is on a distinguished road
Default cotter pin
I'm trying to remove a brake pedal to replace it with a new one. So I figured out the removal of a circlip - turns out I already had the right tool - who knew?? Now I need to remove a cotter pin from the piece that holds the pedal on the bike - but its hard to get to as its under and behind the frame in a narrow space. What is the best way to do this?
jwbookworm614 is offline   Reply With Quote
Old 05-19-2011, 06:29 PM   #2
WintrSol
WintrSol's Avatar
Got a lift?
'68-7? CB450 and '05 S50 Boulevard
Old 05-20-2011, 12:23 PM   #3
jwbookworm614
Master At Arms
got it!
There's such a thing as a "cotter pin extractor" - it looks like an awl with the end bent at a 90ish degree angle. Was able to fit one of those small mirror tools (1" circle) into the space behind the frame to see where the pin was. Used the extractor to push the ends of the cotter pin back around. Then fit the pointy end of the extractor into the head of the cotter pin and levered it out slowly.
Would've been a little easier if I didn't have to hold the flashlight in my teeth. Oh well.
Old 05-20-2011, 12:40 PM   #4
WIP
WIP's Avatar
WIP is on a distinguished road
What about putting it back in?
WIP is offline   Reply With Quote
Old 05-20-2011, 02:32 PM   #5
CookinBeans
CookinBeans's Avatar
CookinBeans will become famous soon enough
Most of the time, a mini hitch pin works well. Looks kind of like a bobby pin.
CookinBeans is offline   Reply With Quote
Old 05-20-2011, 03:35 PM   #6
Gumby73
Jack of all Trades, Master of None
Gumby73 is on a distinguished road
I have the same issue on my bike. I ended up using a pair of extended needle nose pliers I have that have a 90* bend on the tip. It was still a pain for lack of being able to see at first, but it still worked well.
Gumby73 is offline   Reply With Quote
Old 05-20-2011, 03:55 PM   #7
LWRider
Challenged Mechanic
LWRider's Avatar
LWRider is on a distinguished road
I prefer these when possible. I changed my my cotter pin on my rear hub for one. Now it is much easier to loosen the wheel up for those regular chain adjustments, plus the cotter pin was only good for a couple times before it is too weak to take all the bending.
Another thing that can be use is a wire "circle" for lack of a better term; it is something like the ring on a keychain. We used to use those for turnbuckles on sailboats back in the day; they did not catch so much on sheets and clews, etc.
Cheers,
Mike
LWRider is online now   Reply With Quote
Old 05-20-2011, 04:04 PM   #8
Gumby73
I believe the technical term for what you guys are talking about is "hair pin" or "cotter hair pin." It's still a cotter pin but of different shape and durability.
Old 05-21-2011, 12:23 AM   #9
jwbookworm614
Master At Arms
I was wondering about that - substituting some other type of pin that would be equally secure, but a little easier to put in or remove when necessary. A mini hitch pin sounds like a good substitute. Thank you
Search this Thread:
Advanced Search
