weird rattling sound - Motorcycle Forum
Thread Tools
Old 05-12-2011, 06:35 PM   #1
salentino303
Master At Arms
salentino303's Avatar
salentino303 is on a distinguished road
Default weird rattling sound
Hi guys,
Today my bike started making a weird little rattling sound like a loose nut bouncing around the engine I guess.
The rattling happens once I rev over about 4K and , only when I am in gear. If I pull the clutch while rolling, it goes away.
It seems to come from the left side (starter cover) but not sure since I can't really listen to it when not moving.
I already opened up the head and everything looks good in there.
My carbs are synched, but I did notice this morning like a sneezing sound coming from the cylinder #1 when I started her up this morning.
After the rattling started, I made a 180 degree back home driving like a gandma to avoid damaging anything.
The bike is a 91 bandit 400, I would appreciate any guidance on this.
salentino303 is offline   Reply With Quote
Old 05-12-2011, 09:11 PM   #2
CookinBeans
CookinBeans's Avatar
CookinBeans will become famous soon enough
I had one of those about 20 years ago. The only thing I remember is it was too damn fast for me.
I can't even find a parts fiche... So I'll do some guessing;
Clutch retaining nut backing off?
Loose motor mount?
Shift linkage falling apart?
Loose drive chain?
Tap things with a rubber hammer. Grab pieces and wiggle / push-pull, etc.
CookinBeans is offline   Reply With Quote
Old 05-13-2011, 07:26 AM   #3
salentino303
Master At Arms
Indeed, quite a fast bike for such a small engine
I do have the service manual for it. I will tear into it this weekend and hopefully find the offending noise.
Thank you
Old 05-22-2011, 12:38 PM   #4
salentino303
Master At Arms
Arghhhh!!!
I spent countless hours (in between days of raining sessions) tearing every bit of engine I could get to without dropping it out of the frame.
Nada.... When I started, I found and cleaned out a bunch of pebbles stuck around the exhaust pipes (4 in 1 are good at collecting crap in between the pipes) but still felt I needed to go in there to check.
Now, no more rattle...wasted hours, but at least I have a sense of confidence now that everything I went over looked good.
Thread Tools
