Old 05-01-2011, 08:51 PM   #1
marcn
It's all about attitude
marcn's Avatar
marcn is on a distinguished road
Default unknown noise
This is something that has been going on for quite a while. I have a 2002 HD Heritage that I bought used a few years ago, about a year ago I started to hear what I thought was a chain slapping noise coming from the engine compartment.This seemed to mostly happen when there is no load on the engine,say at 55 and just maintaining speed.At first thought it was a primary chain loose so had my mechanic check it out and he said it all looked ok but it still happened. Nothing got worse since then so I let it go.
Now,at any speed, if hitting any size bump in a road I get a noise that sounds like I have metal scraping the asphalt.Almost as if the foot peg is still down,which it's not .At first I thought it was a tire scraping the fender but there is no sign of this happening,then I thought it may be the belt hitting something. I cannot find any indication of anything scraping or hitting that has anything to do with the frame compressing when hitting a bump or dip in the road. Don't know if somehow these two issues are linked somehow or not.It's got me worried now thinking something is going to pop before I can find the problem.The scraping noise happens with the front or back taking a dip,I have plenty of clearance between the tire and fenders. Does anyone have any ideas what to check? Thanks in advance.
Marc
Posted this in the repair section also but this area gets more traffic.
Keep our troops in our prayers
marcn is offline   Reply With Quote
Old 05-02-2011, 01:48 AM   #2
Biker Dash
Site Brony and Troll Eater
Biker Dash's Avatar
Biker Dash has a spectacular aura about
Could that be the sound of it finally starting????
JUST KIDDING! You know a dedicated Honda man has to pick on a Harley, just as a Harley man picks on a Honda...
Seriously though, thinking about it, the primary would be my first place to look. If it was my Shadow, I would be checking the cam chain, but I believe the harley cam is gear driven?
03 Yahama V-max
03 Dodge Ram 1500
Biker Dash is offline   Reply With Quote
Old 05-02-2011, 08:40 AM   #3
OTD
Ole Hamburger Hands
OTD's Avatar
OTD has a spectacular aura about
I been told that they have cam chain tensioner problem in those years that can cause a ton of damage.
OTD is offline   Reply With Quote
Old 05-02-2011, 05:16 PM   #4
marcn
marcn's Avatar
Found it! The ECM unit,which from what I understand is the electronic module that stores the codes and info when diognostic testing, was laying on the rear tire. Weird the way it was positioned on the bike. It was placed under the seat mounted to a plastic panel that was positioned over a rectangular hole in the rear fender.It was held in place by a plastic plug about 1/8" dia through a slot in the plastic mounting panel. Somehow the panel slipped off the plug and dropped through the hole and was bouncing off the tire. Much longer and it would have worn through the module housing and really screwed up some of the electrics.What a stupid design. So a word on periodic inspections of your bike; do it thoroughly.Remove the side bags,which was the only way I found it, remove the seat and do an in depth inspection of your bike.I will do this about once every 3 weeks in addition to my every ride checks. I was just about to pull the primary chain cover and go that route.Thanks for the input though.
Old 05-02-2011, 05:26 PM   #5
OTD
Ole Hamburger Hands
OTD's Avatar
Good self Diag. that's something you can never guess. Good job.
Old 05-02-2011, 05:32 PM   #6
Blaine
Blaine is on a distinguished road
Glad you found it. That is one of the reason I wouldn't care for a Harley, I love their looks but quality seems to be lacking. I'm not meaning to throw mud at those who own them, I just wish the company would put a little more effort into their engineering and quality control.
Blaine is offline   Reply With Quote
Old 05-02-2011, 06:37 PM   #7
Biker Dash
Biker Dash's Avatar
Marc, thats a new one for me lol
Glad that you found the issue. ^_^
03 Yahama V-max
03 Dodge Ram 1500
Old 05-03-2011, 09:24 AM   #8
OTD
Ole Hamburger Hands
OTD's Avatar
Uh....it's a 9 year old bike. Things tend to loosen up on any vehicle over time. You can hardly blame the manufacturer for a part that comes loose after that amount of time.
Old 05-03-2011, 09:41 AM   #9
Badlands-4-2
Super Moderator
Badlands-4-2's Avatar
Agreed.
Glad you found it, especially before it got expensive or painful.
Old 05-03-2011, 09:54 AM   #10
iamjustifyd
iamjustifyd's Avatar
iamjustifyd will become famous soon enough
Glad you found it and didn't turn into an electronic nightmare!! Things over time can vibrate off/loose on any bike.
Sherry 2005 Honda Spirit 750 DC
iamjustifyd is offline   Reply With Quote
Old 05-03-2011, 06:10 PM   #11
marcn
marcn's Avatar
Yea but it's not like my bike shakes like a Har....never mind
Search this Thread:
Advanced Search
