How to fix small hole/leak in fuel tank? - Motorcycle Forum
Go Back   Motorcycle Forum > Motorcycle Repair, Building, and Restoration > Building, Restoration & Modification
Building, Restoration & Modification Building a bike, restoring a classic, or making some modifications?
Thread Tools
Old 05-01-2011, 05:57 PM   #1
nitroz71
nitroz71 is on a distinguished road
Default How to fix small hole/leak in fuel tank?
I just "Evapo-Rust'ed" the tank on my 1980 cm400t. It seemed to get about 90% of the rust out, but it also brought a small hole to my attention. This tank has been soldered and/or welded numerous times from the looks of it. The hole is about 2 or 3mm (tiny), but still leaks a good amount.
My question is: How do i fix it? Should i solder it, weld it, or can JB Weld be used on a hole this small?
Any advice would be greatly appreciated. -Mark
nitroz71 is offline   Reply With Quote
Old 05-01-2011, 06:54 PM   #2
ChriswithaHawk
ChriswithaHawk's Avatar
ChriswithaHawk is on a distinguished road
http://cgi.ebay.com/ebaymotors/1980-...Q5fAccessories
IMHO, I would replace it. kinda something you don't want to have fail you when you are somewhere funky.
ChriswithaHawk is offline   Reply With Quote
Old 05-01-2011, 09:29 PM   #3
nitroz71
Very true. I will probably end up replacing it sometime in the future, but I'm on a tight budget right now, so the cheaper the fix the better. (unfortunately)
Old 05-01-2011, 09:33 PM   #4
nitroz71
Also, thanks for the link. That looks like a decent tank (Alot better than mine). Not sure how i missed that one lol
Old 07-03-2011, 10:46 AM   #5
RowanFaolchu
Newbie
RowanFaolchu is on a distinguished road
There are many many products on the market for that sort of thing, but i am a fan of the good ol' fashioned weld to fix things
RowanFaolchu is offline   Reply With Quote
Old 07-07-2011, 01:02 AM   #6
junker73hd
junker73hd's Avatar
junker73hd is on a distinguished road
I prefer to seal leaks by torch welding or brazing with brass filler.Just be sure to clean the tank thoroughly before hand.
junker73hd is offline   Reply With Quote
Old 07-09-2011, 10:28 PM   #7
jebrown5
Motorcyclist
jebrown5 is on a distinguished road
Try a product called quiksteel. It works...
jebrown5 is offline   Reply With Quote
Old 04-10-2012, 03:08 PM   #8
Gene321
Newbie
Gene321 is on a distinguished road
Default JB Weld for gas tank leak fix
I just sealed a gas leak in a 1968 Honda CD 175 which sat for decads with JB Weld, it had been sealed but the guy must have gave up on the bike when it didn't do the job. But the J B Weld finished up the job correctly.
Gene321 is offline   Reply With Quote
Old 04-10-2012, 03:11 PM   #9
Gene321
Newbie
I brazed a leak in a tank once but even though it was filled with water while I was brazing it it would flash over on me many times so be careful !
Old 05-06-2012, 02:09 PM   #10
ntreece
Motorcyclist
ntreece is on a distinguished road
I would also recommend a good weld to fix the hole, at least until you can afford to get a new tank.
ntreece is offline   Reply With Quote
Old 05-07-2012, 06:53 PM   #11
markk53
Rough Writer
markk53's Avatar
heck I took mine to a fuel tank repair shop where they soldered up the leaks, cleaned the tank and coated the inside with RedKote hard shell lining. Cost me less than $50. They do it for a living, I don't.
KLX650C, Zephyr 550
SR500, Bultaco Sherpa T
Old 05-11-2012, 04:39 PM   #12
csbuckn
csbuckn is on a distinguished road
So many options, I'd probably try JBWeld or welding.
csbuckn is offline   Reply With Quote
Old 05-11-2012, 04:55 PM   #13
gggval
Chris
gggval's Avatar
gggval is on a distinguished road
best option so far by far! for less than $50! that's a crazy steal! first of all they solder and that fixes the problem, but they also seal the tank and that prevents rust from developing! don't try sealinng the tank on your own, its an art!
gggval is offline   Reply With Quote
Old 05-11-2012, 04:58 PM   #14
csbuckn
good point
Old 05-11-2012, 05:02 PM   #15
csbuckn
I do read a lot of post that people say they coated there own tanks with no problems. If you dont get it right, can you get it fixed?
Old 05-11-2012, 07:58 PM   #16
gggval
Chris
gggval's Avatar
not really, they would have to start over, and it doesn't seem easy to get it out of the tank. besides, why would you do that when the kreem tank sealer kits are $50 alone? and they don't include profetional instalation
Old 05-13-2012, 08:52 AM   #17
junker73hd
junker73hd's Avatar
If you decide to go with the KREEM sealer I can save ya some cash.I've got 2 of the jumbo packs for tanks up to 5 gallons.The kits are new and still wrapped in the original plastic.Average retail price is $54 per kit.I'll ship the 3 bottle kit to your door for $40...here's a guide that is as good if not better than the instructions that come with the kit.Thanks,Junker.
How to use KREEM Gas Tank Sealer Kit to seal your gas tank
**This procedure is best done outside.
**Remove any petcock, cap and crossover hoses there may be and seal all openings except the fuel inlet.
**DO NOT get any Tank Prep A (diluted or undiluted) on the painted surface of the tank as it will damage the paint!
How Much Do I Need?
For small tanks (1-5 gallon) use 1 pint bottle of Fuel Tank Liner.
For larger tanks use 1 quart of Fuel Tank Liner per 20 gallons of tank capacity.
Thin Fuel Tank Liner with Methyl Ethyl Ketone to brush or spray on.
#1 - Clean and etch the inside of the tank:
The inside of the tank should be completely free and clear of all loose particulates and corrosion. Even more importantly, it must be totally devoid of any and all oily substances, including any and all traces of gasoline, oil and grease.
Begin Here If Using An Old Or Used Tank - An old or previously used tank may need some extra prep work to get ready for the KREEM treatment. If your tank is really greasy or very rusty begin with this extra step. If you have a unrusted new tank or lod tank in really good condition skip ahead to the application of the Tank Prep A.
Pour about a pint of liquid degreaser full strength into the tank and slosh vigorously with all the openings capped off. Do this for several minutes, and don't forget to invert the tank and get all of the surfaces degreased up around the fuel inlet, as well as the very top of the inside of the tank.
If the inside of the tank is really rusty or has particles stuck to the inside surfaces add several loose nuts and bolts to the degreaser to help break loose the surface contaminates. You may also use a couple 8" lengths of medium size linked chain or anything that will rub against the inner surface and can easily be removed.
Next, add about 1/2 gallon of the hottest water you can get to the degreaser still in the tank and slosh it around again for a few minutes. After you are quite certain that you've degreased all surfaces pour out the entire mixture and remove anything you inserted to help scour the inside surface (nuts, bolts, chain, etc.).
Now pour about a tablespoon of hand dishwashing liquid and about a gallon of very hot water into the tank and slosh thoroughly. Follow with as many cold water rinses as necessary to remove all trace of the dishwashing soap.
Now you are ready to use the Tank Prep A (Wash/Cleaner) that came with your KREEM Tank Prep Kit. This will completely clean and etch the inside surface of the tank.
Begin Here If Using A New Tank - You may begin here with a new tank or begin at the extra cleaning steps listed above if you feel your tank can benefit from the more rigorous cleaning required with old or previously used tanks.
Pour 2 to 2 1/2 gallons (depending on your tank volume) of the hottest water you can get into the tank and add Tank Prep A. Slosh the mixture around for several minutes being sure to get all inner surfaces etched including the inside top and fuel fill area. Sit the tank down for several minutes (10 - 15) between sloshings to let the Tank Prep A solution work. Prop the tank in different positions so the solution contacts all inner surfaces. Leave a small opening in the fuel filler plug to allow gas that is produced during the etching process to escape.
Carefully pour out the Tank Prep A solution into a container for storage so you may use it in the future. Flush the tank with cool water. Inspect the inside of the tank to be sure all rust has been removed and the inner surfaces are etched. Reapply the Tank Prep A solution if needed. Flush the tank with cool water until the rinse water no longer foams and all trace of Tank Prep A is eliminated.
#2 - Remove all water from the inside of the tank:
Perform this step in a WELL VENTELATED area. Immediately pour Tank Prep B (Conditioner) into the tank full strength and slosh it around so it contacts all inside surfaces. Pour the Tank Prep B out and immediately coat the inside of the tank with Fuel Tank Liner.
#3 - Coating:
Pour entire bottle of Fuel Tank Liner into the tank. Coat the interior surface by slowly rotating the tank in all directions. When all interior surfaces have been coated a large excess should remain. Let the tank stand for 10 minutes with the fuel inlet open. Seal the fuel inlet and rotate the tank again to recoat all inner surfaces. Let the tank stand on a different side for 10 minutes with the fuel inlet open. Repeat this process until the tank has the desired coating. Do not let the excess Fuel Tank Liner pool and dry. Drain off excess Fuel Tank Liner for later use.
#4 - Drying/curing time:
Unseal all tank openings. Allow the coating to air-dry for at least 24 hours in a well-ventilated area. If possible extend the drying time to 96 hours (4 days). A nozzle of a low pressure air compressor blowing into the fuel inlet and out another hole can shorten the drying/curing time.
Old 06-02-2012, 02:24 AM   #18
Bede5man
Bede5man is on a distinguished road
If the hole is small, I've heard of drilling it round, then installing a self-sealing flush rivet into it and touch up painting over it.
Never had to do it, just heard of it...
Bede5man is offline   Reply With Quote
Old 06-04-2012, 07:11 PM   #19
ohdark030
ohdark030 is on a distinguished road
Default Youtube
youtube my man -- vids always help more than text if you aqsk me
ohdark030 is offline   Reply With Quote
Old 06-17-2012, 03:08 AM   #20
Batboy
Newbie
Batboy is on a distinguished road
Default JB Weld
It sounds like JB Weld would probably work for a while and only cost a few bucks. Not sure if JB is silocone based but the gasoline may be a releasing agent, I would check that out before I would use it.
Batboy is offline   Reply With Quote
Old 06-28-2012, 07:48 PM   #21
70RT1
Newbie
70RT1 is on a distinguished road
Nitroz, what did you end up doing? I have a tank with two small (1-2 mm) holes and I'm looking for a temporary fix.
70RT1 is offline   Reply With Quote
Old 10-13-2012, 09:33 PM   #22
RRW
RRW is on a distinguished road
Whatever you do, make a permanent repair. JB weld and rivets are not a permanent repair. Imagine going 45 mph down the road with a raging fire between your legs when the fix comes unglued and leaks gas onto the exhaust pipe.
RRW is offline   Reply With Quote
Old 10-19-2012, 03:09 PM   #23
david.ginn524
Master At Arms
david.ginn524 is on a distinguished road
I agree with you try that very good temp solution
but in the long run replace the tank unless, you could coat the whole inside so it doesn't ever rust again and repaint the outside. but that might not be worth it. Idk if it has sentimental value to you.
david.ginn524 is offline   Reply With Quote
Old 12-02-2012, 10:25 AM   #24
WickedMaiden
Newbie
WickedMaiden's Avatar
WickedMaiden is on a distinguished road
I have welded a lot of tanks from rust or collision damage. and each tank presents a different challenge. Sometimes the metal is too rusted to plug weld and requires an extensive patch to be fabricated in. Regardless of repair type, if any heat or welding is to be used, I recommend using dry ice in the tank during this process to eliminate any fumes from igniting.
WickedMaiden is offline   Reply With Quote
Old 12-30-2012, 07:46 PM   #25
levicall
Motorcyclist
levicall is on a distinguished road
j b weld is cheep, dependable, and extremely easy to use. i have used it on multiple cracked heads.
levicall is offline   Reply With Quote
Old 05-02-2013, 06:26 PM   #26
Skinnykid
Newbie
Skinnykid is on a distinguished road
Gotta weld it. I'm almost done with a college welding certificate and when it comes to things like that never cut a corner. I would suggest mig weld. Maybe a shop would do it cheap or someone you know. I'm about to do my brother in law's!
Skinnykid is offline   Reply With Quote
Thread Tools
