Idle RPM speed - Motorcycle Forum
Thread Tools
Old 04-08-2011, 04:47 PM   #1
CHRIS,T
Master At Arms
CHRIS,T's Avatar
CHRIS,T is on a distinguished road
Default Idle RPM speed
Hey guys
i went for a spin on the magna 750 and was wondering why the idle Rom was at 2000 rmp is that normal or is it just a sticky throttle cable ?
CHRIS,T is offline   Reply With Quote
Old 04-08-2011, 05:02 PM   #2
WIP
WIP's Avatar
WIP is on a distinguished road
Google it.
Seriously though. It should be around 1k rpm. If it is that high, maybe the choke is still engaged or the idle needs to be adjusted. What year is this?
WIP is offline   Reply With Quote
Old 04-08-2011, 05:07 PM   #3
CHRIS,T
Master At Arms
CHRIS,T's Avatar
some say 1983 but all my paper work says 1985
Old 04-08-2011, 05:15 PM   #4
Biker Dash
Biker Dash's Avatar
Biker Dash has a spectacular aura about
Magnas idle around 1k. Like WIP said, choke could be sticking, or the idle needs adjustment.
03 Yahama V-max
03 Dodge Ram 1500
Biker Dash is offline   Reply With Quote
Old 04-08-2011, 05:17 PM   #5
WIP
WIP's Avatar
Ok, it should def be around 1k rpm. Is the choke completely disengaged while this is happening? The idle should be adjustable at the carbs. You have to wonder if the person selling it adjusted it high for a reason. Maybe to hide a problem.
Old 04-08-2011, 05:28 PM   #6
CHRIS,T
Master At Arms
CHRIS,T's Avatar
the choke is completely off. and it runs good so ill check the carb to adjust it
1985 Honda Magna 750c
2004 Honda VTX1300
Old 04-09-2011, 08:26 AM   #7
CHRIS,T
Master At Arms
CHRIS,T's Avatar
so i adjusted my carb but it seams to bounce between 1250 and 2000 rpm
2004 Honda VTX1300
Old 04-09-2011, 10:05 AM   #8
CHRIS,T
Master At Arms
CHRIS,T's Avatar
well i did some research and in other forums they say a hole in the exhaust can cause this problem? is this true
2004 Honda VTX1300
Old 04-15-2011, 10:42 AM   #9
HDluvr
Motorcyclist
HDluvr's Avatar
HDluvr is on a distinguished road
I would check for an intake leak also. Air cleaner box secured? Carb to head tight?
HDluvr is offline   Reply With Quote
Old 04-15-2011, 03:27 PM   #10
CHRIS,T
Master At Arms
CHRIS,T's Avatar
no leaks, air cleaner is secured and carbs are tight
2004 Honda VTX1300
Old 04-16-2011, 01:46 PM   #11
alalien
alalien's Avatar
alalien is on a distinguished road
Your idle RPM can be set by the black knob adjuster coming off of the #1 carb.
Idle speeds for Magna's are generally 1200RPM's (is for both my 83 V65 and my 86 VF700).
You're probably due for a carb cleaning, new air filter, and a carb synch. All three you should consider routine maintenance.
Motorcycles require regular maintenance btw. If they don't get it, then they start going downhill quickly.
With all of the threads you have posted, I would suggest the following for your Magna:
  1. Fork Seals
  2. New Battery (if you haven't replaced it already)
  3. Brakes (Front & Rear)
  4. Carb cleaning (buy the gasket sets and replace the gaskets)
  5. New air filter (if you haven't replaced it already)
  6. New spark plugs (if you haven't replaced them already)
  7. Check/Set Valve Clearances
  8. Synch your carbs (you'll need a mercury manometer. Gauge sets are "ok" but the mercury is far better)
  9. Drain & replace the final drive oil
  10. Oil & oil filter change
IF the lead seal caps over the mixture screws on the carbs have been drilled out where someone was just dying to mess with the mixture, then put them back to the default setting for that bike (check the manual for the correct setting. Most are 2 1/2 turns out from bottom). If the seal caps are still there - don't touch them.
All of this, if done correctly, will give you a baseline to start from and shouldn't take a novice more than a weekend to accomplish.
alalien is offline   Reply With Quote
Old 04-16-2011, 02:33 PM   #12
CHRIS,T
Master At Arms
CHRIS,T's Avatar
[QUOTE=alalien;787156]
Thanks
2004 Honda VTX1300
Old 04-16-2011, 04:06 PM   #13
Biker Dash
Biker Dash's Avatar
I'm not certain on the other Hondas, but all the duel carb Shadows seem to come from the factory with the idle mixture screws set incorrectly. I do not know if this was an issue with the Magna, but it may be worth checking into.
The stock setting on a 98 Shadow ACE is supposed to be 2 1/2 turns like you said for the Magna alalian. Mine were at 1 and 1 1/4 respectfully. After adjusting, my bike idled more smoothly and I got rid of most of the decelleration popping and backfiring that happened. If they have to be adjusted, I recommend the red silicone as a sealent afterwards.
03 Yahama V-max
03 Dodge Ram 1500
Thread Tools
