#1 |
I have an extremely cloudy oil sight window which has developed a slight weeping of oil. I have heard of these things popping out and creating an extremely dangerous situation if one happens to be riding the bike at the time. Has anybody ever replaced one of these and how do I get it out?? Is there a special tool I need?
Thanks for any help or suggestions |
#2 |
Administrator
Good luck I didn't even know that they could be replaced , please keep us updated if you make progress
#3 |
Maybe I'm too Old Fart -uh... SCHOOL- but I never heard fo a BMW with a sight window. They all have dipsticks as far as I know.
In any event- get a manual. If that doesn't instruct you, find a model-specific forum if the dealer won't tell you. |
#4 |
Motorcyclist
My K100 has a slight leak around the sight glass, I'd be interested to know how it's done. Have you bought a new glass and if so, where?
#5 |
I did replace it. I bought a new one (2actually so I now have a spare) and did the replacement myself. Getting the old one out was a bit of a bear but not to bad. I ended up punching a hole in the plastic with a pair of needle nose pliers and then reaching in with the needle nose and grabbing the metal plate and levering it out. The new ones have glass not plastic and you have to be very careful putting it back in. I used a socket the same size as the exterior ring and tapped it into place using a small deadblow mallet. A little tricky but doable.
Be careful about getting any plastic inside the motor. The old plastic ones clouded up as a result of heat inside the motor so if you ever even come close to overheating it can pop out, a very bad situation. I took the proactive approach and replaced mine as soon as I noticed the issue.Good luck!! Happy Motoring!! |
#6 |
Motorcyclist
Where did you get the new ones?
#7 |
BMW dealer Max Bmw great website with parts fiche by model/year and they are very helpful on the phone they know all about this problematic part. Cost around 30 bucks.
#8 |
#9 |
Newbie
The oil sight glasses are back in stock now. Check with any BMW dealer.
#10 |
I once had to replace the view window of a brake master cylinder on an old Honda. It was a handlebar mount. I noticed it was foggy, like you said yours was. I press checked it with my finger and it caved in--brake fluid everywhere. I found a replacement for less than a dollar. Easy fix.
