Old 04-02-2011, 12:10 AM   #1
outlawstock27
Motorcyclist
outlawstock27 is on a distinguished road
Question clutch problems
Ok I have an 87 suzuki vs700 intruder. It has 27000 miles on it and I just replaced the friction and steel disks on it. But it still slips after I reach 50mph. What could be wrong with my bike and how do I fix the problem? I am mechanicaly inclined but haven't worked on bikes much. Can anyone help me with this thing?
outlawstock27 is offline   Reply With Quote
Old 04-02-2011, 12:56 AM   #2
CookinBeans
CookinBeans's Avatar
CookinBeans will become famous soon enough
I guess the most obvious guess is you're using car oil? Castrol GTX and the like were great 20+ years ago, but they (and all brands) changed formulas to work with todays car engines. You need a motorcycle-specific oil.
After that, I think clutches wear in after a while, so maybe give it a little more time? Also- how much "play" do you have at the lever? There should be about an eigth of an inch free-play.
CookinBeans is offline   Reply With Quote
Old 04-02-2011, 01:12 AM   #3
primalmu
2005 Bandit 1200S
primalmu's Avatar
primalmu is on a distinguished road
Does the clutch need adjusted? Did you put the clutch springs back in the same places they were originally? Being 20+ years old, you might need new springs anyway.
primalmu is offline   Reply With Quote
Old 04-02-2011, 07:44 AM   #4
outlawstock27
Motorcyclist
Oil, well it has about 10 miles since the last change. And no, I didn't use regular car oil. I am using OEM Suzuki oil. I did think about that prior to changing everything. The clutch springs, well I have ordered them and they should be here in next few days. I just didn't know if there was anything else I could do. Could my slippage problem be comin from somethin else?
Old 04-02-2011, 08:45 AM   #5
Lurch77
Veteran Member
Lurch77's Avatar
Lurch77 will become famous soon enough
I think everyone has mentioned the most common problems. Modern non-motorcycle oils have friction modifiers in them that can cause a wet clutch to slip. You are using a cycle oil, so that is not the issue. The clutch springs may be weak from old age, you have those on order. Hopefully that solves it. And lastly, be sure to check the clutch adjustment. Get a Clymer service manual for your bike if you don't have one. It will pay for itself quickly. It will walk your though proper adjustment of the clutch, as well as almost everything else you might want to do: Amazon Amazon
Lurch77 is offline   Reply With Quote
Old 04-02-2011, 12:41 PM   #6
WintrSol
WintrSol's Avatar
+1 on the springs. On another forum, that has been found to be the most common reason the clutch begins to slip. You can go over 100K miles on the friction discs, but the stock springs take a set early; best replaced with a non-Suzuki, like those from EBC.
'68-7? CB450 and '05 S50 Boulevard
Old 04-02-2011, 08:37 PM   #7
DachshundUberAlles
DachshundUberAlles's Avatar
DachshundUberAlles will become famous soon enough
You might want to check for wear on the RH and LH pushrods as well. A quick check you can do before you do anything else is to slip the clutch a bit. Sometimes a quick heat up will help them seat in. It's worth a try before you tear back into it and won't cost you any wear if it doesn't help.
DachshundUberAlles is offline   Reply With Quote
Search this Thread:
Advanced Search
