Dealing with rust - Motorcycle Forum
Thread Tools
Old 03-20-2011, 02:25 PM   #1
Daz69
Newbie
Daz69 is on a distinguished road
Default Dealing with rust
I'm looking for the best way to deal with rust on various parts of my bike. The spokes and parts of the wheels in particular. Here's what i was thinking of doing. Steel wool the rust off as best as possible. Then polish.
Daz69 is offline   Reply With Quote
Old 03-20-2011, 03:18 PM   #2
Scott1121
Scott1121 is on a distinguished road
You want to use the finest steel wool that you can find with WD-40 or 3-in-1 oil to keep the marring and scratch of the chrome to a minimum. If the spokes are steel and not chromed there's little you can do but scrub and possibly pant them. I have a 1980 honda and have steel wool polished most to all of the rust off of the chrome without many problems!
Scott1121 is offline   Reply With Quote
Old 03-20-2011, 03:43 PM   #3
btracy
Newbie
btracy is on a distinguished road
navel jelly.will help
btracy is offline   Reply With Quote
Old 03-20-2011, 03:48 PM   #4
btracy
Newbie
can u guys help me?i wanted to post a new thread on here,it said i need 3 posts?whats that and how
Old 03-20-2011, 10:31 PM   #5
Gumby73
Jack of all Trades, Master of None
Gumby73 is on a distinguished road
If they're not chromed- or if you're not concerned about keeping the chrome- sandblast them. Steel wool and oil works fine, but if there's any pitting- even pitting starting to occur- there's no guarantee that the wool will be able to get into the pits. What can end up happening, if you refinish, is the finish will "cap" the pits and then you've simply got rust forming unseen.
Gumby73 is offline   Reply With Quote
Old 04-30-2011, 10:54 PM   #6
npe1283
npe1283 is on a distinguished road
metal rescue is great...you have to buy it online...google it..$25 per gallon but it is reusable...GREAT STUFF
npe1283 is offline   Reply With Quote
Old 04-30-2011, 10:55 PM   #7
npe1283
there are youtube clips of metal rescue in action...check them out
Old 05-01-2011, 07:28 AM   #8
JROBER
JROBER's Avatar
JROBER is on a distinguished road
never dull seems to work for me.
JROBER is offline   Reply With Quote
Old 05-03-2011, 05:45 PM   #9
Brentr.
Brentr. is on a distinguished road
I tried EvapoRust. It's "ok" for MILD rust issues. My Metal Rescue should be in today or tomorrow. If it's a heavier rust problem, go with Metal Rescue.
Brentr. is offline   Reply With Quote
Old 05-04-2011, 04:50 PM   #10
OE
OE is on a distinguished road
I read on another forum that tinfoil dipped in soapy water will do the trick.
OE is offline   Reply With Quote
Old 07-18-2011, 03:09 AM   #11
bikemeister
Motorcyclist
bikemeister is on a distinguished road
how did the metal rescue work?
bikemeister is offline   Reply With Quote
Old 07-18-2011, 06:06 PM   #12
pressure1979
Motorcyclist
pressure1979 is on a distinguished road
Blue Magic has something called Chrome and Metal Polish. I think. It will come in a small blue jar. The stuff worked really great on all my chrome that was pitted, and brought it back to life. I highly recommend you have good ventilation when using, and wear protective gloves. For small aluminum or steel parts use No-Rust. Again, I'm not for sure on the name. You can pick it up at Harbor Freight. Place the part in the liquid for about 30 min, then use a wire brush, and BAM, your rust is gone. I love the stuff!
pressure1979 is offline   Reply With Quote
Old 07-23-2011, 01:58 PM   #13
SacDave
SacDave is on a distinguished road
I took the wheels apart on my bike, I used a wire brush on a drill press to clean the spokes, My first thought was to spin them in the drill press and use wet & dry paper but did not want to take a chance of damaging the treads. I used a steel wire brush followed by a brass brush they came out really clean but I did remove what ever finish was left on them. After they were all clean I put 3 coats of gun blue on them followed by a couple rattle can coats of rim clear. I just used steel wool , naval jelly to clean the rims they are pretty pitted no way to get the to look like new.
SacDave is offline   Reply With Quote
Thread Tools
