What happens when your engine cuts off at high speed? - Motorcycle Forum
Notices
Thread Tools
Old 01-30-2011, 10:01 PM   #1
skim1420
skim1420's Avatar
skim1420 is on a distinguished road
Default What happens when your engine cuts off at high speed?
I've always wondered what exactly happens when your engine cuts off at high speed. For example, when you run out of gas. How severe is the deceleration? Am I going over the handlebars if I am completely caught off guard (can't imagine how I wouldn't be.. anyways..)?
I would also guess it matters what gear you're in when this happens. At final gear it's probably not as severe as if you were in first gear. Or more generally, whether you're going fast or at parking lot speeds?
I'd appreciate anyone who's actually had this happen chime in. Thanks
skim1420 is offline   Reply With Quote
Old 01-30-2011, 10:14 PM   #2
DarkHelmet
Banned
DarkHelmet is an unknown quantity at this point
my vtx would chug when the gas was running out and believe me you felt it,,but then i just turn on the reserve. now i have fuel injection and have not tried to test that yet and not sure i want to,,though with the mean streak not sure when id be out of gas,,it has a light,,and that works funny too. it comes on barely,then goes off,,then on again then off then flickers,,then it's not lit all the way,,then it's bright and i know i need to get gas at that point. but it will fade on at about 2 gallons ,,kinda weird if ya ask me.
DarkHelmet is offline   Reply With Quote
Old 01-30-2011, 10:25 PM   #3
Stainlesstehle
A legend in his own mind
Stainlesstehle's Avatar
Stainlesstehle will become famous soon enough
At high speed? You will notice the lack of power, might come and go at first then just slow quickly when the engine quits. (at least on mine being carbureted)
If I'm at the right angle/slope it simply just dies and I need to reach down and flip to reserve, then keep it turning until the gas gets to it. It has only actually totally died once while riding, and I only lost 5mph before it restarted.
2003 VStar 1100
1983 KZ 1100 Spectre
Wife
Stainlesstehle is offline   Reply With Quote
Old 01-30-2011, 10:43 PM   #4
Lurch77
Veteran Member
Lurch77's Avatar
Lurch77 will become famous soon enough
Ride at high speed, and without disengaging the clutch, quickly close the throttle. What you experience is pretty much what would happen in the situation you referenced. The bike will not slow down violently enough to throw you over. You will essentially experience 100% engine braking.
Lurch77 is offline   Reply With Quote
Old 01-31-2011, 12:00 AM   #5
Dylon
Raging lunatic!
Dylon's Avatar
Dylon is on a distinguished road
+1
Happened afew times to me too but as long as you can get to your fuel tap, it shouldn't be a problem!
Unstoppable destructive or crushing force!
Dylon is offline   Reply With Quote
Old 01-31-2011, 10:00 AM   #6
MntShadow
MntShadow's Avatar
MntShadow is on a distinguished road
That should tell you all you need to know about decel on your bike.
I've had to hit reserve several times on mine, Once doing 90+ passing a semi.
If you do have a reserve valve just practice reaching for it several times as you ride so if you need to you can get to it quickly.
MntShadow is offline   Reply With Quote
Old 01-31-2011, 11:59 AM   #7
Hawkeye
├•┤ Pew Pew
Hawkeye's Avatar
Hawkeye is on a distinguished road
Your bike will start to bog down and become "jumpy" before you completely run out of gas. It is pretty noticable.
If you don't sin...
Jesus died for nothing.
Hawkeye is offline   Reply With Quote
Old 01-31-2011, 01:41 PM   #8
ScrumDown
Malevolent Savant
ScrumDown's Avatar
ScrumDown will become famous soon enough
+10
ScrumDown is offline   Reply With Quote
Old 01-31-2011, 02:15 PM   #9
Badlands-4-2
Super Moderator
Badlands-4-2's Avatar
Yes this has happend to me on several of my bikes before I got one with a propper gas gauge. It will cut in and out for a bit before it dies completly. Then it gets real quiet. Also +11 on knowing where the reserve switch is and knowing how to use it, before it is needed.
Old 01-31-2011, 03:50 PM   #10
Hawkeye
├•┤ Pew Pew
Hawkeye's Avatar
My bike has no reserve switch so I just plan on reaching for the clutch if ever in that situation.
The only time I've been there before was my first time on my old ZX-7R and the idiot that sold it to me had tuned the valve off and forgot to tell me about it before I pulled out (didn't even know you could do that before then!)
If you don't sin...
Old 01-31-2011, 04:30 PM   #11
juanitotheclumsy
juanitotheclumsy's Avatar
juanitotheclumsy is on a distinguished road
I'm thinking that, since engine braking is so much stronger in the lower gears, that if you've got it wrapped up leaned way over in a tight turn and the engine suddenly quits, it's just as if you had slammed the throttle closed, and it's high-side time, right?
juanitotheclumsy is offline   Reply With Quote
Old 01-31-2011, 05:24 PM   #12
benny hedges
Veryfried
benny hedges's Avatar
benny hedges will become famous soon enough
if you run out of fuel mid turn the bike will just lose power and roll to a stop. it wont throw you off lol.
try riding it and hit the kill switch to see what it's like..... then hit it back on as you pass some geriatrics!
BOOOOM
anyone had a 2 stroke seize on them at high speed?
notice a bit of a fade then suddenly rararararrrrrr back wheel locks up, clutch it quick and try to coast to safety, pee on the engine and hope it frees off lol!
benny hedges is offline   Reply With Quote
Old 01-31-2011, 06:04 PM   #13
LWRider
Challenged Mechanic
LWRider's Avatar
LWRider is on a distinguished road
When I run out of gas, which is often because of my erratic speedo (Can never tell quite how far I've really gone since fuel up and it doesn't help there's no resettable odo) I generally lose one cylinder of the two. I can usually keep it running on one, long enough to slow down and reach over the tank (Why did they put the cutoff on the right side?) and flip the lever to reserve. Then I have to slow for a bit while the carb float bowls refill. In less than a minute the bike startts acting normally and I can get back on my way at regular speed.
Cheers,
Mike
LWRider is offline   Reply With Quote
Old 01-31-2011, 06:29 PM   #14
DarkHelmet
Banned
i wait till it slows down a bit then jump off,,wooo hooo,,lol
Old 01-31-2011, 06:49 PM   #15
markk53
Rough Writer
markk53's Avatar
Depends on what's happening...
If you're on a two stroke that just stuck a piston as you slide the back wheel down the road before you pull in the clutch if the bike slews sideways place your head between your legs and kiss your you-know-what good bye, you're in deep doo... can you say "hard highside"? Otherwise you just swear a lot as you coast clutch in until you stop off the side of the road.
But if the bike simply runs out of gas or the ignition craps out it will just decelerate at a rate that is dependent on what you're doing. Cruising is no big deal, you'll just slow as if you just closed the throttle. If reving hard you may want to pull in the clutch and coast down over the hard decel. Either way you aren't going over the bars.
KLX650C, Zephyr 550
SR500, Bultaco Sherpa T
Old 01-31-2011, 07:21 PM   #16
badinfluence63
Banned
badinfluence63 is on a distinguished road
You'll get a fair warning, it'll pop and sputter.
badinfluence63 is offline   Reply With Quote
Old 01-31-2011, 07:44 PM   #17
4Raven
Super Moderator
4Raven's Avatar
4Raven has a spectacular aura about
I was just outside of Columbus Ohio when my bike cut out...luckily I was in the right hand lane and near an exit. My bf was behind me...there was no warning..I just pulled the clutch in ...and coasted to the side of the road. That time I ran out of gas.
Another time I was in the passing lane, doing about 70mph, maybe a little faster, and the engine just cut off...no warning nothing, some dude was right on my azz...luckily the car I was passing, passed me , I signaled to get over to the right hand lane, and pulled off the side of the road, again just pulling in the clutch.. have no clue what happened...I think that was when I had the issue with putting bad gas into the tank and still trying to clear it out...
Neither time did my bike decelerate that much that it would have caused a problem, but your biggest worry is no power, people around you, and a quick exit....I just pulled in the clutch and used hand signals..
4Raven is offline   Reply With Quote
Old 01-31-2011, 10:33 PM   #18
sirgilbert357
Rough Writer
sirgilbert357 will become famous soon enough
This is exactly how it feels. I know because I once hit the engine kill switch by accident while on the highway. I just pulled in the clutch, turned the kill switch back to the "on" position, started the bike, then rev-matched it and kept going. Went from about 70 to 50 in that amount of time.
My key to happiness says "Kawasaki" on it.
sirgilbert357 is offline   Reply With Quote
Old 02-01-2011, 08:50 PM   #19
badinfluence63
Banned
Wow see thats why I ride a Harley (and you should to with as much riding as you seem to do) and have never experienced that in over 35 years of riding HD's. Running out of fuel a few times for not paying attention and of course the victim of the proverbial bad gas.
Old 02-02-2011, 10:19 AM   #20
Blaine
Rough Writer
Blaine's Avatar
Blaine will become famous soon enough
The 1500 Goldwing has an angle sensor so if you dump the bike it will kill the engine. My sister has one and asked me to take it for a ride to see if I could figure out what was happening. Go into a turn and lean the bike over and the engine would die. We didn’t know about the angle sensor, it took a while to figure out what was happening. But that is a fun experience to start into a tight turn and have the engine die.
Blaine is offline   Reply With Quote
Old 02-03-2011, 03:23 AM   #21
Stainlesstehle
@ Blaine - Was that a bad sensor or in the wrong position?
2003 VStar 1100
Wife
Old 02-03-2011, 09:27 AM   #22
Blaine
Rough Writer
Blaine's Avatar
It was a faulty sensor, found out Honda had a recall on it, they replaced it for free.
Old 02-03-2011, 11:54 AM   #23
ScrumDown
Malevolent Savant
ScrumDown's Avatar
That would just SUCK!
Old 02-06-2011, 02:46 PM   #24
Hooverdarn
Hooverdarn is on a distinguished road
The reason I joined this forum (today!) was because I was riding my scooter and all of a sudden I lost all ignition. The scoot slowed much like it would have if I'd shut down the gas. The 'unexpected' deceleration was more dramtic than the actuall deceleration.
Now. Anybody know why my scooter suddenly and instantly lost spark? My headlight won't come on but all other electric works... tail light, turn signals, brake light, gauges, etc.
Could it be that when I used a 50 amp boost charge to start it up, I burnt the coil?
Anyone?
Hooverdarn is offline   Reply With Quote
Old 02-08-2011, 03:21 PM   #25
Chuck Heath
Chuck Heath is on a distinguished road
If you're going in a straight line, you'll get the "pop and sputter" routine. If you're laying hard into a curve, you'll get experience in an exercise called "high-siding" which is usually followed by a sensation called "road rash!"
Chuck Heath is offline   Reply With Quote
Thread Tools
