Old 12-24-2010, 04:30 PM   #1
FLBandit
FLBandit is on a distinguished road
Default Seized 2-stroke
Hey all, I'm about to pull the motor from the RD250 frame and I took the heads off to see what was stopping the motor from turning. Well, the pistons are definitely locked to the cylinders. It looks like it could be just from rust. I'm hoping that if I can remove the pistons and jugs that the bottom end will be salvageable. Anyone have a trick for getting the jugs free? So far I've been soaking it with WD 40 and letting it sit. I'm going to try knocking them loose with some wood and a hammer, but am open for any suggestions.
FLBandit is offline   Reply With Quote
Old 12-24-2010, 10:01 PM   #2
Dodsfall
Administrator
Dodsfall's Avatar
PB Blaster is the best I've found for loosening rusted stuff.
2008 XL1200R
Old 12-25-2010, 12:35 PM   #3
FLBandit
Cool, I'll have to pick some up.
Old 01-02-2011, 07:18 PM   #4
LWRider
Challenged Mechanic
LWRider's Avatar
LWRider is on a distinguished road
Strong Arm would be great for that. Miracle sutff, I tell ya. If you find your self in Lake Wales, I'll give you enough to do that.
Cheers,
Mike
LWRider is offline   Reply With Quote
Old 01-12-2011, 12:30 AM   #5
VFR800Van
VFR800Van is on a distinguished road
I would recommend soaking it with pb blaster for a day or two.
VFR800Van is offline   Reply With Quote
Old 01-12-2011, 04:15 PM   #6
OTD
Ole Hamburger Hands
OTD's Avatar
OTD has a spectacular aura about
Yep PB Blaster works wonders.
OTD is online now   Reply With Quote
Old 01-21-2011, 09:47 AM   #7
appalachiantrail2010
Newbie
appalachiantrail2010 is on a distinguished road
I second the pb blaster
appalachiantrail2010 is offline   Reply With Quote
Old 02-02-2011, 10:50 AM   #8
Dave Bowman
Dave Bowman is on a distinguished road
As strange as this sounds if it is a rust seizure, pour a regular red label coke into each cylinder. There is enough phosphoric acid in the drink to loosen and eliminate rust but not enough to score the piston or cylinder. I have freed up a couple of engines using this method. You may have to let it soak a couple of days but it will free it up. Then GENTLY tap the pistons with a plastic dead blow hammer or a piece of wood. If it wasn't heat seized, this should work. I know I am way late entering this thread but this is good info for anyone facing this problem.
Dave Bowman is offline   Reply With Quote
Old 02-10-2011, 10:05 PM   #9
montana.man
Newbie
montana.man is on a distinguished road
try using diesel fuel it works for me
montana.man is offline   Reply With Quote
Old 02-11-2011, 11:45 AM   #10
Johnny225
Johnny225 is on a distinguished road
PB BLASTER. or berryman's b12.
Johnny225 is offline   Reply With Quote
Old 02-12-2011, 07:48 PM   #11
jstewart
Motorcyclist
jstewart is on a distinguished road
I saw a chart of the amount of force it takes to loosen a rusty bolt with different types of products.
wd 40 was the worst followed by pb, liquid wrench was 3rd some expensive brand i never heard of was 2nd and atf mixed with acetone was the best
jstewart is offline   Reply With Quote
Old 02-12-2011, 08:00 PM   #12
Nastorrian
Motorcyclist
Nastorrian is on a distinguished road
strong arm
Nastorrian is offline   Reply With Quote
Old 02-12-2011, 08:56 PM   #13
stroknsmokngt
Master At Arms
stroknsmokngt is on a distinguished road
I have used ATF/Acetone mix, works good.
Suz GT750K Hon CB750C Suz GZ250
stroknsmokngt is offline   Reply With Quote
Old 02-14-2011, 09:58 PM   #14
fouillard13
Motorcyclist
fouillard13 is on a distinguished road
atf and wd <40 and lots of patience.
fouillard13 is offline   Reply With Quote
Old 02-14-2011, 09:59 PM   #15
fouillard13
Motorcyclist
lightly tapping the cylinders with a rubber mallet always helped me
Search this Thread:
Advanced Search
