Old 09-29-2010, 03:38 AM   #1
Biker Dash
Site Brony and Troll Eater
Biker Dash's Avatar
Biker Dash has a spectacular aura about
Default Cleaning a K&N filter
Ok, I know this sounds like a stupid question, but how do you properly clean a K&N air filter? And how long after cleaning the filter do I have to wait befor applying the K&N filter oil to it?
(I overdid it with the filter oil when I put the K&N on the bike lol)
03 Yahama V-max
03 Dodge Ram 1500
Biker Dash is offline   Reply With Quote
Old 09-29-2010, 05:19 AM   #2
aaronrkelly
I use the filter/charging kit from K&N.
Basically you spray the cleaner on....wait.....and rinse with low pressure water.
After cleaning you have to wait for it to dry NATURALLY. Do NOT use compressed air as it will damage the filter. You can set it in front of a regular fan but thats it.
Then apply the oil and you need to wait for THAT to dry before running it.....or you may suck oil into the intake, which isnt a good thing.
The whole process takes awhile figuring the dry time - I know ALOT of guys that run K&Ns have 2 filters so they can always have 1 ready and they arent setting around a day without riding waiting for their filter.
Old 09-29-2010, 07:17 AM   #3
Eye_m_no_angel
Super Moderator
Eye_m_no_angel's Avatar
Eye_m_no_angel is a jewel in the rough
I use Zep brake cleaner to clean the filter, as it dries in minutes and leaves no residue. Then lightly spray with K&N filter oil, re-instal, and go for a ride.
If you put a little too much oil on it's no big deal as it's kind of self correcting. Through use the extra oil will get sucked into the engine (no problem with that) and the right amount will be left clinging to the filter material.
Eye_m_no_angel is online now   Reply With Quote
Old 09-29-2010, 07:28 AM   #4
Stainlesstehle
A legend in his own mind
Stainlesstehle's Avatar
Stainlesstehle will become famous soon enough
Do any motorcycles have MAF sensors? If you over oil a K&N filter on a car with a MAF sensor you will have run ability issues. The extra oil coats the hot wire and gives the computer false readings.
Thats ONLY if your bike is fuel injected with a MAF sensor. I don't know if any do, but over oiling can be an issue on a car
God Bless You
-Mark-
Stainlesstehle is offline   Reply With Quote
Old 09-29-2010, 09:14 AM   #5
HKshooter
HKshooter is on a distinguished road
Good points.
I'll add that K&N airfilter oil does not dry or otherwise it would not work because it's the oil that does the filtering, not the cotton. I spray one pass down each pleat and that's plenty. Install, go riding.
HKshooter is offline   Reply With Quote
Old 09-29-2010, 01:23 PM   #6
Biker Dash
Biker Dash's Avatar
Would carb cleaner work? I have a can of that stuff.
03 Yahama V-max
03 Dodge Ram 1500
Old 09-29-2010, 07:56 PM   #7
HKshooter
I havent tried it but I'd be afraid it might attack the rubber it's made of. Personally I use Castrol SuperClean. Spray liberally, let soak, wash out under hot running water, let set in the sun for a few hours. Spray oil, install.
They say to avoid using compressed air and I agree with this. But a coworker of mine used to use it all the time at low pressure and from the inside out and never seemed to have any problems. I still avoid it.
Old 09-29-2010, 08:37 PM   #8
smooth1
smooth1's Avatar
smooth1 is on a distinguished road
I've always used the regular K&N cleaning fluid. After the filter's dry I put the oil on a little at a time & let it soak in before applying more oil. I got too much on my wife's car filter awhile back. If you follow the directions it takes awhile to clean dry & apply the oil.
smooth1 is offline   Reply With Quote
Old 09-30-2010, 12:23 AM   #9
Eye_m_no_angel
Super Moderator
Don't use the carburetor cleaner.
Old 09-30-2010, 01:15 AM   #10
Biker Dash
Biker Dash's Avatar
Actually, both the Mechanics I deal with up at Starting Line (two guys I HIGHLY recommend to anyone with a bike here in Maine) said I would have no issues using carb cleaner.
So I tried it.
And it did the job just fine.
03 Yahama V-max
03 Dodge Ram 1500
Old 09-30-2010, 07:35 AM   #11
getlower666
getlower666's Avatar
getlower666 is on a distinguished road
i dont clean becouse every year got new bike with new k&n but i would use only water
getlower666 is offline   Reply With Quote
Old 09-30-2010, 11:02 AM   #12
Easy Rider 2
Banned
Easy Rider 2 is on a distinguished road
The filters are coated with OIL.
Water won't do much (like nothing) to clean them.
Easy Rider 2 is offline   Reply With Quote
Old 09-30-2010, 11:54 AM   #13
robow
Ninja Robot
robow's Avatar
robow will become famous soon enough
I would think that carb cleaner and brake cleaner would be to strong of a solvent, but I guess if it worked its fine. I know at auto parts stores you can get the K&N filter cleaner kit for about twenty dollars.
robow is offline   Reply With Quote
Old 09-30-2010, 07:51 PM   #14
Eye_m_no_angel
Super Moderator
I suppose it depends on what KIND of fluids you have. The carburetor cleaner we have in the shop is extremely flammable, will burn your skin and it will also soften paint. The Zep brake cleaner we have is much less volatile and is completely safe to spray on painted surfaces. Plus, it cleans the filter elements very well and very quickly.
The carburetor cleaner that you can buy in a can from the auto parts store might not be as volatile though. (It also doesn't do as good a job cleaning carburetors.) Hey, if you're not sure just get the K&N kit as was mentioned.
Old 09-30-2010, 07:52 PM   #15
Eye_m_no_angel
Super Moderator
Thanks for the chuckle.
Old 09-30-2010, 09:23 PM   #16
Easy Rider 2
Banned
When a nub 14 year old shows up and proceeds to tell all of us the "truth" according to him.......humor helps......to keep from crying or flying too far off the handle.
Search this Thread:
Advanced Search
