Old 09-06-2010, 11:55 PM   #1
littlehop
littlehop's Avatar
littlehop is on a distinguished road
Default GN400 flat spot
Hey all,
I've been working on this bike for a few weekends and its kick starting and running smoothly now, but at 4000 rpm it just drops off and almost dies. this occurs without a load and with a load on engine. So far the tank has been cleaned, carb completely gone through three times, adjusted valves which were spot on when checked. ?? There is alot of carbon on the piston face and I can see some on the exhaust valve. Not sure were to go from here.
Will the carbon build up cause this and can it be removed without disasambly?
littlehop is offline   Reply With Quote
Old 09-14-2010, 12:39 AM   #2
littlehop
littlehop's Avatar
This bike is a suzuki gn400 1980-81 and I still havnt found a suitable air cleaner huosing, its just runnuning with a screen right now. Any recommendations on an aftermarket replacement instead of stock. Maybe this will help the problem.
Old 09-14-2010, 08:35 PM   #3
Massoodk
Massoodk is on a distinguished road
Hey, i have a similar problem with my 1980 GN400. It struggles when getting to about 4,000 rpms and doesnt want to go any higher. If i hold the throttle open mine will also stuggle really bad and start to die out. I found some others with similar problems to ours and their problem was the CDI unit. Im still not positive what is going on with mine. Ill let you know if i found anything else out. Heres the link to the other forum.
http://www.totalmotorcycle.com/BBS/viewtopic.php?t=6714
O and im running a UNI Filter on mine instead of the stock air cleaner.
Massoodk is offline   Reply With Quote
Old 09-14-2010, 09:03 PM   #4
littlehop
littlehop's Avatar
Thanks Massoodk, I have a second cdi I'll try out and see if that changes anything. I have not seen many cdi's for this bike out there for sale, I wonder if another brand cdi could be subbed, say maybe a honda in the same class size? The voltage may be the biggest issue.
Old 09-14-2010, 09:33 PM   #5
Massoodk
Yea, no problem. Let me know if it foxes your problem. I found two listed on ebay for like 100 and then the oem is nearly 300 off bikebandit.com.
Old 09-14-2010, 09:48 PM   #6
littlehop
littlehop's Avatar
Yeah I saw the ebay ones but I'm nervous to spend that kind of money on electric parts that look just like the old ones I have, I'll be more likely to go stock on this part from bike bandit.
Search this Thread:
Advanced Search
