Handlebar Grip Glue - Motorcycle Forum
Thread Tools
Old 08-08-2010, 10:28 PM   #1
Lurch77
Veteran Member
Lurch77's Avatar
Lurch77 will become famous soon enough
Default Handlebar Grip Glue
The grips on my old Suzuki started slipping and oozing a gray substance. upon inspection I found a previous owner used a layer of electrical tape, then a a few layers of duct tape on the bars. I can only assume he was trying to enlarge the bar diameter to make the grips stick better?
Anyway, the grips are in good shape, I cleaned them up, and they slide onto the cleaned up bars tightly. Now I need to reinstall them properly. In all my years of ATVing and cycling I have never installed a set of grips.
Besides dedicated grip glues, what other substances have worked well for this? I want to get this done tomorrow and I am not sure dedicated grip glue will be available. I assume the stuff is just some sort of rubber cement? If it matters, the grips are a rubber like type made by Pro Grip.
Lurch77 is offline   Reply With Quote
Old 08-08-2010, 11:30 PM   #2
aaronrkelly
Rough Writer
I use weatherstripping adhesive....works great.
Old 08-08-2010, 11:31 PM   #3
WintrSol
Rough Writer
WintrSol's Avatar
I get grip glue at my local independent MC shop; it looks and smells like a rubber cement. You can probably use an equivalent from your local hardware store, provided they still something like that.
Old 08-09-2010, 02:06 AM   #4
67fire
Banned
+1 for Weatherstrip Adhesive.
It comes in Black also.
Eric
Old 08-09-2010, 09:25 AM   #5
Badlands-4-2
Super Moderator
Badlands-4-2's Avatar
If you can find it, a product called, Shoe Goo works. It is a type of rubber cement the stays flexible and bonds most anything.
Old 08-09-2010, 09:45 AM   #6
MntShadow
MntShadow's Avatar
MntShadow is on a distinguished road
I don't know about other types of grips but when I bought my Kuryakyn ISO grips they came with 2 little bottles of glue that were rock hard in the bottles, I emailed the place I bought them and in the mean time checked on another forum and was told they used superglue, Well I went and got a tube and used it on the grips and a few days latter I received a new bottle of glue in the mail and low and behold it was in fact a type of superglue.
But the weather stripping glue sounds like a great idea.
MntShadow is offline   Reply With Quote
Old 08-09-2010, 11:12 AM   #7
iamjustifyd
Rough Writer
iamjustifyd's Avatar
iamjustifyd will become famous soon enough
I've replaced grips twice and following the directions on the package, no glue was used. A few drops of dish washing liquid in water and leave them alone overnight. If I remember right, you and use alcohol too.
2007 Yamaha FZ6
iamjustifyd is offline   Reply With Quote
Old 08-09-2010, 11:28 AM   #8
benny hedges
Veryfried
benny hedges's Avatar
benny hedges will become famous soon enough
Originally Posted by iamjustifyd View Post
use alcohol too.
that's probably great til the next morning when you wake up with a headache and realise you put the left grip on the right side.....
benny hedges is offline   Reply With Quote
Old 08-09-2010, 11:53 AM   #9
iamjustifyd
Rough Writer
sigh...rubbing alcohol benny
2007 Yamaha FZ6
Old 08-09-2010, 12:45 PM   #10
jclaude
Motorcyclist
jclaude is on a distinguished road
This might sound crazy but the best/worst thing I have used for grips is WD40 when it cured you almost had to peal them off...
jclaude is offline   Reply With Quote
Old 08-09-2010, 10:56 PM   #11
Lurch77
Veteran Member
Lurch77's Avatar
Thanks for all the replies everyone. Definitely some different ideas out there. In the end I ended up stopping at one of my local dealer after all. A cheap bottle of grip glue and a new set of grips. It seems to be set up good after only an hour, but I won;'t be riding the bike until this weekend. The glue says to set at least 24 hours.
Old 08-10-2010, 10:40 AM   #12
markk53
Rough Writer
markk53's Avatar
Old off road tricks -
Hair spray - back when most were some sort of laquer type, don't know how the new stuff works
Spray paint - most garages have a can of something sitting around.
I just did spray paint on the grips for the Zephyr - Rustoleum semi-gloss black for those who might wonder.
Sprayed it on some cardboard, wiped a paper towel in it and smeared it on the bar/throttle tube. Then I used an air gun to blow the grips on, having blown off the old junk ones. The paint sticks them to the bar/throttle tube.
KLX650C, Zephyr 550
SR500, Bultaco Sherpa T
Old 08-10-2010, 10:43 AM   #13
rexmitchell
Administrator
rexmitchell's Avatar
+1 but no soap is necessary, see here http://www.motorcycleforum.com/showthread.php?t=92603
Thread Tools
