what kind of oil do you use? - Motorcycle Forum
Go Back   Motorcycle Forum > Manufacturers > Yamaha
Thread Tools
Old 08-04-2010, 04:07 AM   #1
snake572
Newbie
snake572 is on a distinguished road
Default what kind of oil do you use?
i got a '92 seca ii and wanna put synthetic oil in it what kind do you reccomend ive heard amsoil was a good route and i use royal purple in all my vehicles but bike are different so i need some more opinions. And also i was told to stay away from K&N air filters i love K&N so i need you guys to comment on that and tell me whats the best route taken for air filters because i go with K&N for everything and im confused on that one.
snake572 is offline   Reply With Quote
Old 08-04-2010, 08:46 AM   #2
cbdallas
Rough Writer
cbdallas's Avatar
cbdallas will become famous soon enough
My issue with K&N is the amount of crap it allows into the intake. I've seen several used-oil analyses done by guys on various car forums where silicon levels in their oil went through the roof after they installed a K&N. Any extra (and barely noticable) power you gain isn't worth the extra engine wear, and I can't imagine why you'd want to hassle with washing / oiling when you can just pop out / pop in, and go for a ride.
I'm somewhat on the fence about synthetic oils in my bike at the moment, as I recently switched to Rotella T in my Ninja. The synthetics have made all my bikes shift loud and rough, but the Rotella really smoothed it out. Any small amount of shear or thermal breakdown I'm experiencing by using a conventional oil is worth not hearing my gears crashing together every time I shift. I change my oil often enough that I doubt I'm doing any harm.
cbdallas is offline   Reply With Quote
Old 08-04-2010, 10:19 AM   #3
Easy Rider 2
Banned
Easy Rider 2 is on a distinguished road
My first question always is: WHY ??
There is really no good reason that I can see for doing EITHER of the things you propose.......except it might make you feel good somehow.
Switching to synthetic in a ~19 year old bike is probably a waste of time and money.
Same for the hyped K&N filters.....unless maybe you own a machine shop are are going to do a complete performance rebuild. A K&N alone on a bike often makes the performance worse, not better......and the filtering is not as good.
My personal opinion: Just ride it and enjoy it for what it IS. If it ain't broke, don't F*** with it.
Easy Rider 2 is offline   Reply With Quote
Old 08-04-2010, 12:07 PM   #4
KMWilliams
Super Moderator
KMWilliams's Avatar
KMWilliams will become famous soon enough
I concur with everything said above about K&N. K&N filters allow to much dust through. This has been proven numerous times on car forums. If you'd like, I can point to the one on TDIClub were oil was sent out to a 3rd party for testing.
Synthetic oil, I use Elf / Total. But on your bike I think Easy is correct about it being a waste of money. It would be like me putting synthetic in my 92 Ford truck.
KMWilliams is offline   Reply With Quote
Old 08-04-2010, 12:31 PM   #5
justin68106
Rough Writer
justin68106's Avatar
justin68106 is on a distinguished road
Have you put Amsoil in? I never heard my gears when shifting with that in my 09 ninja 250. I always use Amsoil, it's expensive, but worth it IMO.
justin68106 is offline   Reply With Quote
Old 08-04-2010, 05:35 PM   #6
markk53
Rough Writer
markk53's Avatar
I don't run K&N especially on the dual sport because of dusty conditions in which I ride. The street bike has a foam Uni in it due to price.
I simply run motorcycle oil from the local motorcycle shop, running whichever 10W-40 is least costly. If I wasn't close to a shop I'd do the same at another source. I may pay a bit more, but there is never any question about friction modifiers or anything else, besides I'm usually in the shop for the OEM oil filter too. Same could be done for synthetics too. Again no issues with the filter when it's OEM. I've seen where one company made a mistake in the O-ring on a canister that cost a guy an engine.
Actually as long as there are no additives that could affect anything, any oil can work in a bike, especially if you go with the ridiculously conservative 1950s change intervals most riders do. I run about 5000 miles and actually would go more, but if I use that generality I usually have the oil changed by at least 6000. I don't short hop my bike, it nearly always gets up to full operating temperatures, especially since I started using the bicycle for short hop stuff around town (better for the legs and wind). That cooks off any moisture and the oil will stay in good shape longer.
One thing I will say is that in 22 years in and around a shop I've never seen an oil failure. I've seen filters put in 250 Honda singles backward and aftermarket misfits, along with running oil too low, but never a true oil failure. So I'd never say Amsoil, Rotella, Castrol, or any other oils for cars won't work well. They probably will. I just play it absolutely safe, relying on the manufacturers and oil engineers to make the best call with their motorcycle product.
KLX650C, Zephyr 550
SR500, Bultaco Sherpa T
Old 08-05-2010, 12:31 AM   #7
justin68106
Rough Writer
It's not the engine I'm concerned about with car / truck oils in my bike, it's the clutch. If I had a dry clutch I guess it wouldn't matter, but I've been told moly is bad for your wet clutch and will cause you to need new ones more often.
Old 08-05-2010, 10:25 AM   #8
Easy Rider 2
Banned
Yes, that is true. I haven't seen any posts in this thread that suggested otherwise.
The damage to the clutch is often almost immediate. It sometimes can be "fixed" by going back to the right oil; sometimes not. It's a BIG gamble.
Old 08-18-2010, 06:57 PM   #9
TobsMaxim
TobsMaxim's Avatar
TobsMaxim is on a distinguished road
I run Valvoline 10W-40, and I have no complaints about it
TobsMaxim is offline   Reply With Quote
Old 08-22-2010, 06:32 AM   #10
tomsonsllc
tomsonsllc is on a distinguished road
Is there a best oil with bikes, like cars where Royal Purple is King?
tomsonsllc is offline   Reply With Quote
Old 08-22-2010, 10:47 AM   #11
KMWilliams
Super Moderator
KMWilliams's Avatar
No.
Trolling Trolling Trolling, down the info highway, TROLLING! (whip crack)
By the above, I mean that Royal Purple is considered to be a divisive topic on all the forums I read and post. It got so bad on my TDI site, you can get banned for bring it up.
Old 08-22-2010, 08:36 PM   #12
Easy Rider 2
Banned
The best oil is whatever you THINK is best.
Since you like Royal Purple, I think they make bike oil too.
Problem solved.
Old 08-22-2010, 08:43 PM   #13
rexmitchell
Administrator
rexmitchell's Avatar
Don't bother with synthetic on a bike that old, waste of
money, if you use something like amsoil
it will clean the gunk out of your gaskets and make you have leaks, run some cheap conventional oil and change it regularly. I commend you on wanting to run the best but it's not worth it in your case
Old 09-04-2010, 01:56 PM   #14
cturek
cturek's Avatar
cturek is on a distinguished road
Default What kind of oil
I belong to the XJbikes.com group and there we all agree that using synthetic oil is not a good idea as the friction modifiers plays h$ll with the wet clutch. I swear by Shell Rotella. Good basic oil at a reasonable price.
Carl
1982 XJ750 Seca / 1980 XS400
cturek is offline   Reply With Quote
Old 09-04-2010, 02:01 PM   #15
justin68106
Rough Writer
You need to use motorcycle specific synthetic oil so those friction modifiers aren't in the oil to ruin your wet clutch.
But I probably wouldn't spend the money on synthetic oil for either of the bikes in your signature due to their age.
Old 01-31-2011, 12:47 AM   #16
Ron Hochhauser
Ron Hochhauser's Avatar
Ron Hochhauser is on a distinguished road
Just talk to an AmsOil Dealer! No on the Filter.
Ron
Ron Hochhauser is offline   Reply With Quote
Old 02-05-2011, 09:52 AM   #17
partsman8475
partsman8475's Avatar
partsman8475 is on a distinguished road
They are right about the synthetic oil. That old of a bike it may do more harm than good. I would stick with a motorcycle grade 10w40 or a 20w50 depending on the weather conditions.
partsman8475 is offline   Reply With Quote
Old 02-17-2011, 02:02 PM   #18
nikola11
Motorcyclist
nikola11 is on a distinguished road
Justin what do would u say aboyt your 09 ninja 250?
nikola11 is offline   Reply With Quote
Old 05-20-2011, 12:57 AM   #19
charliealley
Newbie
charliealley is on a distinguished road
My comments on the oil. A close friend was senior reserce tech in the fuel and emmisions lab at the shell reserce center in Houston. We were questioning oil because of the clutch. he got some engeneers to do some tests on it and they determined that automotive oil today had so many friction reducing additives to get gas mileage up that it was best to run diesel truck oil in the bikes. so the guys up there that was sugesting Rotella are right on track. this is also why the man said his bike shifted better with Rotella.
charliealley is offline   Reply With Quote
Old 09-12-2011, 09:25 AM   #20
alarmguy
alarmguy is on a distinguished road
You are 100% correct. I have a Vstar 1300-
Rotella 15/40 (also Jaso MA rated) or Delo LE 400 15/40 (my favorate for silky smooth shifts) or Vavoline blue 15/40 or Mobile 15/40
The bottom line is they are oils that are made to withstand the tortures of the world biggest and baddest diesel engines with an API commercial rating of CJ-4 and also API automobile rated SM. Best of all, they will keep your engine super clean, made to withstand shearing and right in the viscosity range recommended by Suzuki for your V Star 1300.
Anyone who never tried Rotella or Delo 15/40 is in for a treat when it comes to shifting ...
alarmguy is offline   Reply With Quote
Old 09-12-2011, 02:06 PM   #21
jetmonkey
Newbie
jetmonkey is on a distinguished road
FWIW, I completely agree. I had a '87 Maxim that I wanted to treat really well after I inherited it so I asked around about switching it over to synthetic & I got the same feedback most of the bike mechanics I spoke to: 'Not necessary'. Now, my 02 Street Glide needed a complete bottom end rebuild after I bought it & I started using synthetic after that.
jetmonkey is offline   Reply With Quote
Thread Tools
