Danger of using your engine to slow down - Motorcycle Forum
Go Back   Motorcycle Forum > Motorcycle Forums > Motorcycle Training, Safety, and Riding Techniques
Motorcycle Training, Safety, and Riding Techniques Ask questions of motorcycle instructors and share riding techniques and safety tips
Thread Tools
Old 05-19-2010, 01:01 PM   #1
dewaine
Survivor
dewaine's Avatar
dewaine is on a distinguished road
Exclamation Danger of using your engine to slow down
And I realize in some circumstances it is o.k. to slow down using the engine, by shifting down. But in most cases this is the more dangerous way to slow down.
The reason is that, by downshifting to slow down, you are depending on the traction of the ground/pavement to force the rear wheel to keep turning, albeit at a slowing rate. If the surface traction is not sufficient to keep the wheel turning against the force of the engine (that is trying to slow the wheel down) the engine power will exceed the road resistance, and the rear wheel will nearly completely stop.
In my case, I shifted from 3rd to 2nd gear, just a few feet before the steel storm drain grate. That grate had about zero traction for my knobby tires. When I went over the storm drain, the rear tire slowed to probably around 5 mph, but my motorcycle was still travelling at about 25 mph. When I reached the other side of the storm drain my rear tire met the far greater friction of the road -- still going nearly 25 mph, but with my rear tire rotating at about 5 mph. This was nearly a dead stop for my motorcycle, and it fell over about 4 feet on the other side of the storm drain, and I went over the front tire.
For more information on my incident, see this:
http://www.motorcycleforum.com/showthread.php?t=101529
dewaine is offline   Reply With Quote
Old 05-19-2010, 01:12 PM   #2
rustydog
I fear no beer
rustydog is on a distinguished road
Any type of braking on a slick surface can cause you to lose control.Glad your ok,safe riding!
rustydog is offline   Reply With Quote
Old 05-19-2010, 01:15 PM   #3
dewaine
Survivor
dewaine's Avatar
That is right. I guess I wouldn't have hit the brakes because of the slick surface, but I wasn't thinking about NOT shifting down. A newby (like I was at the time) might not realize the power forcing the rear wheel to slow when down-shifting.
Old 05-19-2010, 01:24 PM   #4
YamahaFan
Certified Homeless Biker
YamahaFan's Avatar
YamahaFan is on a distinguished road
I think when people talk about engine brake they meant to roll the throttle back (release the throttle?), not to downshift without pulling the clutch in (I definitely don't do this unless my clutch's broken)
1996 Yamaha FZR600, first and current bike, and loving it. RIP Pat Taylor aka iamgumby
I'm into women in leather. No whip please. It's not my style.
YamahaFan is offline   Reply With Quote
Old 05-19-2010, 02:29 PM   #5
dewaine
Survivor
dewaine's Avatar
I actually pull in the clutch, shift down, then release the clutch. It really slows the MC down!
Old 05-19-2010, 02:42 PM   #6
porange
Rough Writer
porange's Avatar
porange will become famous soon enough
I engine brake ALL the time, saves on brake pads! =P I never downshift with blipping the throttle though
porange is offline   Reply With Quote
Old 05-19-2010, 03:57 PM   #7
internationalballer
internationalballer's Avatar
internationalballer is on a distinguished road
I engine brake all the time. I think the moral of this story, as well as your other nearly identical post is to be aware of the road conditions you are on. Metal railroad crossings, painted lines, manhole covers, especially when wet are going to have far less traction. Engine braking isn't really that dangerous, being un aware of road conditions is.
internationalballer is offline   Reply With Quote
Old 05-19-2010, 04:46 PM   #8
cmack
Master At Arms
cmack's Avatar
cmack is on a distinguished road
As to the OP his quote on the link he provided sums it up:
"I agree, now that I think about it -- it would have been just as bad had I hit the brakes. The main problem in my case was I was distracted by a car backing out of a driveway, and I forgot about the storm drain. But I have been putting a lot more thought into the issue down-shifting."
It's really not the down shifting to slow down that was dangerous, but the braking circumstances at the time. This does give us all something to think about though.
cmack is offline   Reply With Quote
Old 05-19-2010, 08:18 PM   #9
67fire
Banned
Same here!
I NEVER do NOT use the engine for braking.
(Even on ice. Just in a higher gear for the condition.)
Always be aware of what you are riding ON.
There was another post not too long ago where the poster said that
"he saw the fresh painted lines that were not there the day before",
and STILL slipped on it!
The clue was there!
He still turned on it!
Bottom line: pay attention and stay upright.
Eric
Thread Tools
