Go Back   Motorcycle Forum > Motorcycle Forums > General Motorcycle Discussion
General Motorcycle Discussion If it doesn't fit in any of the motorcyle forums below, post it here.
Old 07-11-2012, 10:21 AM   #1
shatz
Motorcyclist
shatz is on a distinguished road
Default Ninja 250--Disappointing fuel economy
My husband used to own a 2002 Ninja 250 and got 60-70 mpg on it. He recently bought a brand new Ninja 250 and, though driving it about the same, is only getting 40 mpg. Most of his driving is on the highway, commuting to work, and he is not overly aggressive with it. Any thoughts on why the fuel economy is so much worse?
shatz is offline   Reply With Quote
Old 07-11-2012, 01:53 PM   #2
cbdallas
cbdallas's Avatar
cbdallas will become famous soon enough
If the carb has been adjusted to run rich, MPGs will suffer. Any intake / exhaust mods? These bikes are tuned at the factory to run quite lean, but if that's been adjusted, it won't achieve its normal high MPG numbers.
Tire pressure, brake caliper condition, atmospheric & weather conditions, warm-up times, choke partially stuck on, oil type & viscosity, altered final drive (sprocket sizes), & spark plug condition can all contribute to reduced MPG.
cbdallas is offline   Reply With Quote
Old 07-11-2012, 02:00 PM   #3
CaptCrashIdaho
Safety Hooligan
CaptCrashIdaho's Avatar
CaptCrashIdaho will become famous soon enough
How to say this...
OK, there's kind of a 'sweet spot' for MPGs--rev too low and you'll knick your mileage. Likewise if Hubby was running the bike at good RPMs for long periods on the freeway (no stops & starts) he was in that sweet spot a long time. My Phantom gets 55mph in town, 60 if I keep it under 70 on the freeway and it drops under 50 if I'm running 75+ for long periods.
Isn't the new Ninja fuel injected? It also might not be broken in yet and unconsciously he might still be babying it. Until it's fully run in it won't settle to it's final mpgs...
Kawasaki feels he should be getting 61 freeway so my money's on the thing ain't fully mature and he's shifting early and often.
CaptCrashIdaho is offline   Reply With Quote
Old 07-11-2012, 03:56 PM   #4
shatz
Motorcyclist
It's completely stock for now. I'm pretty sure it's carbureted. Hopefully it just needs breaking in...our checkbook misses those 70mpg!
Old 07-11-2012, 05:49 PM   #5
MirrorrorriM
MirrorrorriM's Avatar
MirrorrorriM is on a distinguished road
It's carbureted. Check the pressure of the tires. If I had to venture a guess, I would bet on that. Go by what the label underneath the seat says - don't eyeball it, motorcycle tires are tricky in that they may look inflated, but are 20psi under!
-Clark
MirrorrorriM is offline   Reply With Quote
Old 07-12-2012, 10:46 AM   #6
Hawkeye
├•┤ Pew Pew
Hawkeye's Avatar
Hawkeye is on a distinguished road
That doesn't sound right to me either. Something wrong for sure (could be tire pressure + some other little things). Has the oil been changed 2 times yet? Not sure that would have a large effect on the MPG but helps a little from my experience.
For reference I get about 40MPG driving aggressively on my R6...
If you don't sin...
Jesus died for nothing.
Hawkeye is offline   Reply With Quote
Old 07-12-2012, 07:51 PM   #7
croz
croz is on a distinguished road
I used to have an 08 Ninja 250 and I got 50 mpg wringing its neck on the backroads.
croz is offline   Reply With Quote
Old 07-12-2012, 08:11 PM   #8
RobMoore
RobMoore's Avatar
RobMoore will become famous soon enough
I had a 2011 250 that I'd have wound out all the way most of my 70 mile commute (which equated to 98-103 mph). It got 46mpg.
RobMoore is offline   Reply With Quote
Old 07-14-2012, 07:39 PM   #9
Hawkeye
├•┤ Pew Pew
Hawkeye's Avatar
Since the bikes top speed is 115 that is pretty unbelievable...
If you don't sin...
Old 07-14-2012, 11:19 PM   #10
RobMoore
RobMoore's Avatar
115? Not even going downhill.
Old 07-15-2012, 01:10 AM   #11
zmago
zmago's Avatar
zmago is on a distinguished road
With a tailwind.
zmago is offline   Reply With Quote
Old 07-15-2012, 03:00 AM   #12
tkkronic
tkkronic is on a distinguished road
115 top speed??
tkkronic is offline   Reply With Quote
Old 07-15-2012, 08:55 AM   #13
goalie
goalie is on a distinguished road
A friend looked at the Ninja before buying the CBR. Stats on the Ninja were impressive for the little engine -- over 100 top speed (I think it was 105 officially) from only 36 hp and 15 to 18 ft lbs of torque.
Definitely enough to have a heck of a lot of fun around town.
goalie is offline   Reply With Quote
Old 07-15-2012, 08:58 AM   #14
goalie
Guess my memory was wrong. This Cycleworld article says the Ninja only got 25.5 hp on their dyno.
http://www.cycleworld.com/2011/03/04...mparison-test/
Old 07-15-2012, 09:02 AM   #15
RobMoore
RobMoore's Avatar
Engine hp vs wheel hp
Old 07-15-2012, 09:05 AM   #16
goalie
Re-looking at the article, I guess I'm not sure. I want to say they were talking about ... but I cannot say. I guess if I wasn't so lazy, I'd check the official website.
Old 07-15-2012, 10:06 AM   #17
RobMoore
RobMoore's Avatar
No, I was saying that 36 versus 25 is the difference between engine horsepower and wheel horsepower. When a magazine says they dynoed it, they mean wheel horsepower which is lower than engine horsepower. Manufacturers claim engine horsepower.
Old 07-15-2012, 11:33 AM   #18
kat569
kat569's Avatar
kat569 will become famous soon enough
This. My Ninja 500R (2009, bought brand new) was getting 50-60MPG until I let the tires lose pressure; then it dropped to about 40MPG. Once I added 15 or so pounds to each tire, my MPG went right back up.
When life throws you curves, lean into them...
kat569 is offline   Reply With Quote
Old 07-15-2012, 11:47 AM   #19
Team Elkhorn
VP in charge of Diddly Squat
Team Elkhorn's Avatar
Team Elkhorn is on a distinguished road
It will probably get better fuel mileage after it gets broken in. But...How can I ask this nicely? Has he gained any weight since the first Ninja.
Team Elkhorn is online now   Reply With Quote
