| Building, Restoration & Modification Building a bike, restoring a classic, or making some modifications? |
The 1968 Scrambler that I am fixing is going to take less time than I thought. The tires are holding air, but the outer rubber is dry rotten and I dont trust them.
The front is 3.00X19 The rear is 3.50X18 The front is not the issue, but can I put a 4 or 4.5 in the back?? Thanks Dave ![]() |
Special Member
Often wider rims (or even wider tires on the stock rim) will strike the swingarm.
Are tires not available for your OEM rim?
'07 Ninja 500R, formerly '81 Yamaha XS400 |
They are, just looks thin.
I will say you probably can run a 100/90-19 on the front and a 110/90-on the rear without much problem. Those are what is frequently recommended for the old 350s and such. I believe that was what we used to sell to all the guys with 350s and such. Most of us back when used to replace the 3.50 rears with 4.00s. I believe I did so on my 75 Kawasaki S3 400 triple and my brother did so with his RD400.
I do have a question if you're referring to an old CL72/77 Honda 250/305Scrambler - who replaced the back wheel, they were usually 19s front and rear.
KLX650C, Zephyr 550 SR500, Bultaco Sherpa T |
Yes it is a Scrambler and you are correct. But it is a 3.50/18 in rear and 19/3 in front.
Is the discussion above applicable to the '72/'73 scramblers as well?
In addition, does anyone have any thoughts regarding how aggressive a tire one can use while still being able to travel 65 or 70 mph safely? Thanks |
#7 |
It should work on the later years too. If you want to run real authentic tires, get a pair of Dunlop K70s if they'll fit. I ran them on my old SR500 single no problems at any speed I ran, plus they work fairly well on dirt/gravel since they were run on flat trackers pre-1975 or so.
KLX650C, Zephyr 550 SR500, Bultaco Sherpa T Last edited by markk53; 11-28-2011 at 04:48 PM.. |
#8 |
That's good to know, although I am looking to get as aggressive as I can without completely sacrificing highway performance/safety.
I plan on using the bike in northern minnesota where there are a lot of defunct iron mines interlaced with trails and unmaintained roads, and also old logging roads. Essentially I would like to be able to blast along the paved highways, then drop off-road and explore wherever there are interesting places to do that. So I need to strike a balance between off-road and pavement performance. Any advice on that is appreciated. Also I am considering gearing the bike down a little so that I won't need to feather the clutch at very low speeds while navigating between trees, rocks, etc. Thanks |
#9 |
Been looking thru older posts and this is exactly my question....My 72 Cl350 looks anemic with that 350/18 on the back...I want a beefy tire back there. But, I dont like the look of the metric tires. Want a vintage look. Any suggestions?
