Go Back   Motorcycle Forum > Motorcycle Forums > General Motorcycle Discussion
General Motorcycle Discussion If it doesn't fit in any of the motorcyle forums below, post it here.
Old 07-14-2012, 06:00 PM   #1
bamcoy40
bamcoy40 is on a distinguished road
Default honda 71' cb100 fuel line help
I'm not sure where things like this are supposed to be posted but i need help. I'm restoring an old honda cb100 and am stumped on what i thought would be the easiest step. there are 3 line, 2 from the carburetor and one that goes into the engine. where do the lines go? i know one from the carb goes to the tank valve nipple. where do the other 2 go? any help is appreciated! thanks.
bamcoy40 is offline   Reply With Quote
Old 07-14-2012, 06:37 PM   #2
goalie
goalie is on a distinguished road
Lets see... playing with old Hondas is filed under "animedevildog."
goalie is offline   Reply With Quote
Old 07-17-2012, 10:23 AM   #3
LWRider
Challenged Mechanic
LWRider's Avatar
LWRider is on a distinguished road
There is a line running into the carb from the tank (4.5 mm) and another one (smaller diameter, 3.5 mm) running from the carb float chamber drain. You said "three"? Is one of those pretty large diameter? Perhaps an oil breather tube? Schematic doesn't show that, but usually there is a breather tube running from the top of the engine back and down as a kind of vent. Could that be the one that "goes into the engine"?
Cheers,
Mike
LWRider is offline   Reply With Quote
