Things to look for when buying a used bike(CHECKLIST)
I feel like almost everyday we go over some basic stuff in different threads regarding what to look for when buying a used bike. Instead of repeating this information over and over again, I am going to stick this thread in the hopes that it will help some new buyers(and old ones) in some basics to look for when purchasing a used bike. Feel free to add on to the list and I will edit the post to make it cleaner.
1. Check fluid levels--Oil, brake fluid, coolant levels, etc. Also if you can look at the oil and its condition. A bike with fluid levels that haven't been maintained, especially the oil could mean trouble. 2. Tires- Tires are often neglected, but can run a few hundred bucks right off the bat. Make sure they are not brittle or cracked, no nails, plugs, or flat spots. Check the tread life, you can go through tires quick so be prepared to replace them if the tread is low. 3. Chain/belt drive--Rusty chains will need to be replaced, see how much slack is in the chain. Check for kinks in the chain and if possible put it on a rear stand and spin the back tire to see how the chain looks. Properly lubed chains should be free of rust and move smoothly. 4. Frame--Look for damage in the spots on the frame that are most likely to be scuffed up in a crash or drop. Check out the sub-frame on sportsbike as this can be bent(get behind the bike and make sure the rear end lines up over the rear tire) Check the stator cover, and the clutch cover for touch up paint(touch up paint is a sure sign the bike has been down one way or another). Forks, check for leaks or cracked seals, this could be a couple hundred bucks easy. 5. Fairings--Make sure they line up and match up. Slightly different colors could mean replacements from a crash, misaligned fairings could mean the same. Beware of "custom" or new paint jobs, most of the bikes I have seen repainted were repainted because they were down and the fairings were bondoed instead of being replaced. A warning with street figher/naked bikes that weren't originally a naked bike. Most bikes that are streetfightered have been wrecked and instead of replacing parts, the bike was chopped down to a fighter, just know that going to look at a fighter. 6. Handle bars--Check the ends of the bars for scraps, another sign the bike has been down. Turn them both ways as far as possible, there should be some clearance on the gas tank. Check to make sure all levers move freely and the throttle is smooth both ways. 7. Pegs--look over the pegs, see if they are scrapped, another way to tell if the bike has hit the ground.( Also with aftermarket levers, another red flag that they might have been replaced due to a crash). 8. Electronics--Check to see that all lights and blinkers work, check the condition of the battery, and all wires leading to it. A dead or weak battery is another 90 bucks or more to have to replace. 9. Forks- Check to see that the forks are true and straight. Check the fork seals for leaks, any oil coming out of them is a sign they will need to be replaced and it isn't cheap, also if the fork oil leaks down to the brakes a rebuild on them is necessary as well. 10. On the bike--If riding, and you are comfortable, let go of the bars and see if the bike rides straight at 20-30 mph, it should, also check for any excessive shaking. Check brake condition, and acceleration. Also if possible hear the bike start up from a cold start. You can hear a lot of weird noises on startup that won't be there once the bike is warm. Let the bike run to operating temperature and make sure it doesn't overheat and that the radiator fan(if applicable) turns on. 11. ASK ALOT OF QUESTIONS-- The best thing to do when buying something used is to ask every question you can think of. I.E. How long have you owned the bike? What problems are you aware of? When was the last oil change? Valve adjustment? Does it pass inspection? Has it ever been down, or dropped? Asking these questions will help you get a feel for the buyer and a lot of times people are 100% honest about things like that, but you won't know until you ask. Hope this helps and anything to add please do. Good hunting and good luck guys and gals!:71baldboy: |
great checklist! The only thing i could add, because I just bought a bike and forgot to do it... make sure that the exhaust coming out of both mufflers is strong and matching the other. You want to know if you're getting into carb problems. Great list!
Rub the muffler outlet. If you get a lot of black on your
finger, it's probably an oil burner. Smell the oil cap. If it smells burnt, the oil hasn't been changed often enough. Smell the oil fill hole. It should not smell like gas. It should not smell like a junkyard. It's hard to tell what it should smell like, but if you are a man, it's a smell you wouldn't mind having on you except in church. If you are a woman, it will smell like a man, a real man. Look at the color of the brake fluid. If it is dark, it hasn't been changed often enough. (Not such a big deal but it tells about maintenance in general.) Check how snugly the chain fits the rear sprocket. If you can pull the chain away from the sprocket (at the rearward most part of the sprocket) it is worn. If you can see through between the chain and the sprocket, it the chain is all used up, and it has been using up the sprockets as well. You will need to replace both. Look for wear on the sides of the sprocket(s). This shows misaligned rear wheel from adjusting the chain wrong. If only the outside ends of the pegs are scraped, it means the owner is a good rider. If the whole peg is scraped, the owner is a lousy rider. Check the wear on disk brake pads and the wear indicator pointer on drum brakes. These items are not reasons to reject a bike, unless too many of them are bad. They mostly affect how much you will need to spend soon, so you would adjust your price negotiations. |
Good advice there, thanks for adding that.
You want the bike to be started from a cold condition. If a seller knows you are coming,he may start it up to have it warm. Feel the engine before he starts it for you. Also you may want to feel the pipes right off a cold start. One pipe that heats more slowly says something about carb adjustment or perhaps even cylinder condition.
Check the seat, don't just think ow that easy fixed it can coast a couple of hundred dollars for reupholstering.
Another thing on dirtbikes check the fork seals if they are leaking then thats a sing the bike has taken a bit of a beating. Also if the bike look shiny new and all the fluids are near new then be suspecious. |
I was about to buy a bike yesterday, and I ran the VIN, found out it was salvaged in another state.... But I just bought my first bike through a Harley Dealer, it is sweeeeeet! CAUTION CRAIGLIST ADS!
On the point of Craigslist ads. Definitely beware of any ads or emails from sellers proposing a long distance transaction brokered by Autotrader, Craigslist, or some other company. This is absolutely a sign to run for the hills. The bike should be correctly priced (not too low), and you should be able to sit on the bike personally and run through the checklists recommended in this forum.
Great thread for us newbies!
I made a Word document based on the information here so I can bring it with me as a checklist when I check out bikes. My first section is the ID the bike Make, model, year, VIN, owners name, NADA price, KBB retail price, asking price (I may leave off KBB since it seems to be on the high side). There is also a reminder to myself to check to be sure the engine isn't hot and space for a couple sentences for general impressions of the bike and its condition. The next section is set up in Word as tables so I can check off condition (good, average, poor). The section headings with their subsections (subsections are in parenthesis, the semi-colons separate each subsection) are: Fluids- smell, look, levels (oil; brake fluid; coolant levels) Tires (brittle/cracked; nails/plugs/repairs; flat spots; tread life) Chain (Rust; slack; sprocket wear) Electric (lights; blinkers; battery, wires) Signs of accident/drop (frame; dents, paint/scratches; chrome- dents/scratches; footpegs or boards and handlebars) Engine (Exhaust from both mufflers; sound; pulls strong; sticking throttle) The last section is made of the questions I don't want to forget:
Thanks guys for the idea. This will really come in handy when I check out bikes. Edit: I tried to attach the file in case anyone wanted to see it or was interested in using it. Unfortunately, the file is larger than I can attach on this forum. If you are interested, PM me and we may need to exchange emails so I can send it to you. Unfortunately, it would probably be easier just to make your own checklist. |
Jeff, just copy and paste it into a post.
It loses the tables when I try to do that, so it really doesn't look much better than above. Since I lose the tables, I've reformatted it for the forum so you circle the condition of each item instead of a check box on a table. BTW- the way some items are combined into one where separate items may be better (such as chain/sprocket condition) allows it to all fit on 3 pages in the original formatting with plenty of room for you to record the answers to the questions.
Used Motorcycle Checklist Make: _______________________________________ Year: _________________ Model: ______________________________________ N.A.D.A.: _______________ Owner: ______________________________________ KBB Retail: ______________ VIN: _________________________________________________ Asking price: ___________ Note: make sure engine is cold- want to test cold start Overall Condition/Impression: Fluids (levels, look- is it clean, and smell- does it smell burned) Oil Good Average Poor Brake fluid Good Average Poor Coolant levels Good Average Poor Tires - Brittle/Cracked Good Average Poor Nails, plugs, repairs Good Average Poor Flat spots Good Average Poor Tread life Good Average Poor Chain (sprocket wear, can chain be pulled from sprocket) - Rust/Slack/Overall Condition Good Average Poor Electric - Lights Good Average Poor Blinkers Good Average Poor Battery and wires Good Average Poor Signs of accident or dropped bike: - Frame (lines up, bent) Good Average Poor Dents Good Average Poor Scratches in paint Good Average Poor Scratches in footpegs/boards and end of handlebars Good Ave Poor Scratches or dents in chrome/muffler Good Average Poor Engine: - Exhaust from both mufflers Good Average Poor Sound Good Average Poor If ride on it, pulls strong Good Average Poor Throttle doesnt stick Good Average Poor Questions: How long have you owned it? When was last oil change? When was the last valve adjustment? Did it pass inspection? Has it ever been dropped? Why are you selling? Is it paid off/is there a lien or do you have a clear title? |
Very nice, that should be a good tool for people to use, thanks for posting that.
Hmm, filling out the top part of my form for the first time today while preparing to go look at a bike I noticed one glaring omission. I didn't include an entry for miles. So, I figure right under asking price (next to the note about a cold engine) may be a good place for that.
If the exhaust is disolored by the heads how much damage could have been done to the engine? Knowing that it was probably run to lean (they changed the pipes but didn't adjust the fuel) does it do major internal damage? If so can you tell without pulling the heads to check the valves?
That seems a little more than most bikes I have seen but I will let a crusier rider chime in.
my bike has stock pipes, and has significant bluing very similar to that picture. one thing to note, i have an inline 4 engine on my cruiser, all four headers come out the front, and all four are blue'd almost the same distance. might be different for v twin like yours.
just wanted to say thanks for this, its really helping me out in my search
oh and yeah, its very informative |
Excellent material - thank you all!
I'll be using this. . . |
thank Mr.rexmitchell
Good info, wish I would have read this before I bought mu y 82 Nighthawk, good info nonetheless. BZ
WTG! (again/as usual) Rex!!! :thumbsup:
Eric :) |
Things to look for when buying a new bike
my 2 cents to add would be check for leaking fluids. look for tell tale signs in the hard to clean places deep between the crankcase and tranny. as well bounce the front forks to check for leaky seals and if they look too clean then there's probably a reason.
This is great information. Especially for those of us looking on Craig's list.
I have one question though, what is the difference between a bike being "dropped" and "laid down"? Thanks! |
Technically, I would say laid down means a zero-speed drop, resulting in very minor damage if any at all. That's definitely not always the case where advertising is concerned. People tend to gild the lily about the condition of used bikes when selling them. I wouldn't disregard a bike that has been dropped when buying used. They should be checked over carefully, however. |
Hey, thanks a lot. Im about to make an offer on this bike and know im not gonna feel like an idiot when I talk to this guy. Lot of great info. You guys are awsome
Good luck on the bike, let us know waht you get
Anything you ask may not bring you to the truth. Keep your eyes open at all times. If you are not the first time rider, you know where to look!
Vin #
If you ask an owner for the VIN, how do you "check" it? Where do you go & what information is provided?
Thanks, Jarrett. |
thanks
thanks for the hints love this site :71baldboy:
Also, I would check to see if the owner has the title or if there are the bike has been registered. It would suck to go to the DMV and find out that the owner hasb't paid since 1989.
Sure wish I would have read this before I bought my bike. Took my hubby with me, but he didn't really do much. After I took it home, I figured out that the guy hadn't really been taking care of the bike. Tire pressure half what it should have been. No oil change. Dirty/dark brake fluid. Sticking throttle. Difficult to start, probably dirty spark plugs. Nothing major that I've found, but I'm putting in a bit of money to get it up to speed.
the best thing to buy a used bikes its ride it,,,,,,good luck
| All times are GMT -4. The time now is 07:40 PM. |
Copyright ©2004 - 2011 CrowdGather, Inc.
