How to Bleed Your Brakes
September 30, 2009 by iamgumby
There have been a lot of questions about bleeding hydraulic systems for brakes and clutches. I thought that a DIY on this subject may be valuable. This is pretty straight forward and easy to do.
Let’s start with a couple of basic precepts. Hydraulic fluid does not compress but it does pressurize. That is why hydraulic systems work. Your hand moves a lever that moves a piston. The piston moves fluid from the master cylinder down the line into the caliper. The caliper’s piston’s move outward and apply the brakes. You grip tighter and the caliper grips tighter. You let off the handle, the pressure releases and the spring in the master cylinder returns the piston drawing fluid back into the master cylinder. A check valve in the master cylinder keeps the fluid and pressure one-way during application.
Air is a problem in a hydraulic system. Air does compress. If air is in your hydraulic system a portion of the hydraulic effort that should be pressure making a component move is now compressing air and not giving you maximum efficiency. In fact, it may result in a crappy or dangerous situation. “Bleeding” is the activity that removes air out of the hydraulic system.
Brake fluid (also used in hydraulic clutch applications) has a tendency to degrade over time. Best practice is to change the brake fluid every year. Pick a day…Birthday…First Day of Spring…Easter…Memorial Day…doesn’t matter - just pick a day and change your fluid out every year on that day. It will only take one container. Cheap insurance in my opinion. “Flushing” is the activity that removes the old hydraulic fluid from the system replacing it with clean fluid. Flushing is only bleeding with a different goal and purpose.
Brake fluid is one of the most efficient paint strippers known to man. Remember Murphy’s Law, “If it can go wrong, it will go wrong at the worst possible time”. Murphy was an optimist. Go prepared.
What will you need? Depends on your machine to a bit. A large old towel to protect your machine. Screwdriver to remove the master cylinder cover. Appropriate wrenches to open and close the bleeder valves. Plastic tubing to control the flow of the waste fluid; and a container for the same. New container of the appropriate type of brake fluid for your machine from a reputable manufacturer.
Step 1: Protect your painted surfaces with toweling.
Step 2: Locate your bleeder valves (some machines have one for each half of each brake caliper, others only one per caliper/slave cylinder). Clean away any dirt or debris near the bleeder. Hopefully it has a cap to keep crap from stopping up your bleeder. Bleeder caps are your friends.
Step 3: Loosen and re-tighten your bleeder valves without any pressure in your system - just to make sure none of them are seized. Just crack it open and closed to make sure it moves.
Step 4: Place tubing on your bleeder to control waste fluid. You do not want it shooting out on any painted surfaces. It is good to have a container to route the fluid to. I use IV bags. EMS types are your friends.
Step 5: Wipe away any debris from around your master cylinder. Remove the screws and raise the cover. Inspect the diaphragm for dry rot or tears. Wipe all the small parts down with a clean lint free rag (t-shirts & diapers rock).
Step 6: Inspect & Evaluate. Brake fluid is supposed to be generally clear. A member here described his as, “looking like pancake syrup”. If you have a reason to bleed your brakes there is a good chance you should be flushing your fluid while you’re at it. Look in the bottom of the master cylinder for…what I call black dust. If you have black dust or brown fluid use a baster bulb to draw the fluid out. Use q-tips, pipe cleaners or an old piece of clean T-shirt on a screwdriver tip to get that black dust out as well as any residual fluid. Put nothing into your hydraulic system other than the appropriate type of clean (new) brake fluid.
Step 7: Once the master cylinder is clean top it off with new fluid.
Consult your owner manual or read the master cylinder’s cover for the correct grade of fluid. Lightly install the cover back in place.
Be sure that your check valve cover did not get dislodged or lost. They can pop loose while cleaning. They will pop right back in - they only fit one way
Start pressuring the system by pulling the lever back and forth rapidly about 10 - 25 repetitions. When you have a firm lever, hold it back against the bar.
Step 8: Starting with the caliper that is farthest from the master cylinder (left side front dual disc) open the bleeder valve. This might require an assistant. I usually assign my assistant to running the lever. When the bleed valve opens fluid and air will spit out (or just fluid - using clear tubing will help you see what’s going on) and the lever will release to the bar. DO NOT LET GO OF THE HAND LEVER WHILE THE BLEEDER VALVE IS OPEN. That will suck air into the system through the bleeder valve and cause more problems than you had when you started. Close the bleeder valve, then let go of the lever and continue the cycle of pumping, holding and releasing. Once the far side runs clear, change to the near side.
Step 8: Repeat this basic process for the clutch hydraulic system as well as the back brake system. One can usually do those without an assistant.
The black dust? That is usually a sign that the rubber components inside the hydraulic system are starting to break down. I know that my clutch system is almost ready to be rebuilt. The fluid gets nasty in about 3 months. I have the cylinder rebuild kit on hand but still need to get the stainless steel brake line upgrade.
Maintaining your brake system is low cost and easy. It will pay dividends when you have to replace pads and do not have to deal with stuck or leaking pistons and cylinders. An efficient brake system is essential to safe riding.
Comments
Reply
Certified Homeless Biker
YamahaFan's Avatar
Wow I must say it's really in your blood - the brake fluid that is
Use that IV bag often?
To be honest I rarely looked into the master cylinders, but after looking at your picture I'd better start looking into mine
Thanks,
Old 06-02-2009, 10:51 PM YamahaFan is offline
#2
I am the Vanilla Gorilla!
rexmitchell's Avatar
Great write up, I'm glad someone finally did one, I am going to stick this.
Old 06-02-2009, 11:26 PM rexmitchell is offline
#3
Administrator
Dodsfall's Avatar
I would have never thought about using an IV bag to catch the fluid. I've always used mayonnaise jars or something similar.
Great idea!
Old 06-03-2009, 07:20 PM Dodsfall is offline
#4
YamahaFan's Avatar
I use a clear bottle. Ain't got any IV bag because I'm not that old yet
Old 06-03-2009, 09:56 PM YamahaFan is offline
#5
Administrator
Dodsfall's Avatar
I know a guy that drives a meatwagon. I wonder if he can snag a couple for me.
Old 06-03-2009, 09:57 PM Dodsfall is offline
#6
Quote:
Whatever grandpa!
Old 06-03-2009, 10:10 PM rexmitchell is offline
#7
Verified
WVEngraver's Avatar
Definitely a much needed how too. I've found it's easier to pull the fluid from the caliper with a giant syringe ..... which you can buy at a farm store. Just connect it to the bleeder with some surgical tubing and draw it out .... filling the reservoir as needed. Once all the air is out, close the bleeder and pump up the brakes by squeezing the lever.
Old 10-02-2009, 01:02 AM WVEngraver is offline
#8
Newbie
psbros's Avatar
Good Info
Thanks Some Good Info
Old 02-02-2010, 07:22 PM psbros is offline
#9
Verified
Great Thread this helps me a TON. Now I might finally be able to bleed my Honda CB750 brakes. Although I may need a new master cylinder. Thanks!
Old 03-09-2010, 12:58 PM Chicago535 is offline
#10
Motorcyclist
Great post, I'll have to do this pretty soon.
Old 03-28-2010, 02:11 AM Renton is offline
#11
Verified
thx for this might get the job done now lol
Old 03-28-2010, 06:16 AM tazzmadness is offline
#12
Motorcyclist
bleeding brakes issues
Just have a question regarding bleeding the brakes. I'm restoring a '75 CB 360T and I followed the how to bleed your brakes thread above to the letter. I installed new pads, reassembled, and reattached the caliper, and brake line. Cleaned out the master cylinder. Piston at the brake lever was a little sticky, but got it working. Added new fluid, but CANNOT get any pressure built up with the bleeder valve closed. Any ideas as to where to check or what I'm missing or doing wrong? Any input would be appreciated....thanks.
Old 03-28-2010, 01:57 PM fullernh is offline
#13
Fuller, is there air in the line, have you tried to bleed them again and see if there is air bubbles?
Old 03-29-2010, 01:57 AM rexmitchell is offline
#14
Motorcyclist
bleeding brakes
No fluid at all in lines. With master cylinder filled, bleeder valve open or shut, and pumping brake lever, no fluid enters the lines. I even detached brake line at master cylinder, and pumped brake lever....no fluid exits master cylinder. Brake lever doesn't build up any resistance. Holes in bottom look clean and clear. I'm going back out now to try all again....
Old 03-30-2010, 03:15 PM fullernh is offline
#15
Motorcyclist
okay, got something to work. Bleeding brakes successfully, but now brakes seem to be on constantly and pads won't release disc. Tried adjusting bolt at caliper with no luck.
Old 03-30-2010, 04:55 PM fullernh is offline
#16
Motorcyclist
This info will definitely help once I get my bike and start doing stuff, but the pictures don't show up for me. Could it be they got removed from wherever they were hosted ? Could someone put pics up or do another write-up with up to date pics next time they bleed their brakes ? Just an idea to help keep the forum current and awesome ;-D
Old 05-03-2010, 11:57 PM Jeimuzu is offline
#17
Newbie
Thanks
Thanks, this helped tremendously, glad to see the write up
Old 06-16-2010, 08:14 PM nhunting is offline
#18
Looking for something?
Search our community forums:
Search
crowdgather  A member of the Crowdgather Forum Community
Powered by WordPress      |       Legal
Visit our other communities
A few highly recommended forums...
Sponsors
